hello, can i do 16d0wq with vvdi prog adapter(35080)? what succes rate?
If I helped, dont forget use buttons reputation+thanks
VVDI without the adapter works
Can you erase this chip without adapter?!?!
yes testing BMW 6WA 160dowq and 6WB 160Dqwt
samux (30th August, 2018)
hello samic i need pic18f252 on freelander immo pinouts , in list vvdiprog you have this option for pic18f252 but no schematic in help ., please thanks
taxo1965 (2nd October, 2018)
VVDI PROG latest software version V4.7.4 update
v4.7.4 (2018-08-27)
* This version DON't need update firmware
* Fix some bugs
+ Add VVDI PROG USER MUNUAL 4.7.4 version in Doc folder
+ Add MX25L512E, MX25L1005, MX25L1025, MX25L1006, MX25L1026, MX25L2005, MX25L2006, MX25L2025, MX25L2026, MX25L4005, MX25L4006, MX25L4025,
MX25L4026, MX25L4033, MX25L4035, MX25L8005, MX25L8006, MX25L8025, MX25L8032, MX25L8035, MX25L8036, MX25L8073, MX25L1602, MX25L1605, MX25L1606,
MX25L1608, MX25L1633, MX25L1635, MX25L1636, MX25L1655, MX25L1673, MX25L3205, MX25L3206, MX25L3208, MX25L3225, MX25L3235, MX25L3236, MX25L3239,
MX25L3255, MX25L3273, MX25L6405, MX25L6406, MX25L6408, MX25L6435, MX25L6436, MX25L6445, MX25L6446, MX25L6455, MX25L6465, MX25L6473, MX25L12805,
MX25L12833, MX25L12835, MX25L12836, MX25L12845, MX25L12865, MX25L12873 options in <1-EEPROM&FLASH>-><MXIC>
+ Add MX25L1025(CLIP), MX25L512E(CLIP), MX25L1005(CLIP), MX25L1006(CLIP), MX25L1026(CLIP), MX25L2005(CLIP), MX25L2006(CLIP), MX25L2025(CLIP), MX25L2026(CLIP), MX25L4005(CLIP),
MX25L4006(CLIP), MX25L4025(CLIP), MX25L4026(CLIP), MX25L4033(CLIP), MX25L4035(CLIP), MX25L8005(CLIP), MX25L8006(CLIP), MX25L8008(CLIP), MX25L8025(CLIP), MX25L8032(CLIP),
MX25L8035(CLIP), MX25L8036(CLIP), MX25L8073(CLIP), MX25L1602(CLIP), MX25L1605(CLIP), MX25L1606(CLIP), MX25L1608(CLIP), MX25L1633(CLIP), MX25L1635(CLIP), MX25L1636(CLIP),
MX25L1655(CLIP), MX25L1673(CLIP), MX25L3205(CLIP), MX25L3206(CLIP), MX25L3208(CLIP), MX25L3225(CLIP), MX25L3236(CLIP), MX25L3239(CLIP), MX25L3255(CLIP), MX25L3273(CLIP),
MX25L6405(CLIP), MX25L6406(CLIP), MX25L6408(CLIP), MX25L6435(CLIP), MX25L6436(CLIP), MX25L6445(CLIP), MX25L6446(CLIP), MX25L6455(CLIP), MX25L6465(CLIP), MX25L6473(CLIP),
MX25L12805(CLIP), MX25L12833(CLIP), MX25L12835(CLIP), MX25L12836(CLIP), MX25L12845(CLIP), MX25L12865(CLIP),
MX25L12873(CLIP) options in <1-EEPROM&FLASH>-><MXIC(CLIP)>(Need EEPROM CLIP ADAPTER)
+ Add W25P10, W25P20, W25P16, W25P32, W25P40, W25P64, W25P80, W25Q10, W25Q16, W25Q20, W25Q32, W25Q40, W25Q64, W25Q80, W25X10, W25X16, W25X20,
W25X32, W25X40, W25X64, W25X80, W25P128, W25Q128, W25X128 options in <1-EEPROM&FLASH>-><WINBOND>
+ Add W25P10(CLIP), W25P16(CLIP), W25P20(CLIP), W25P32(CLIP), W25P40(CLIP), W25P64(CLIP), W25P80(CLIP), W25Q10(CLIP), W25Q16(CLIP), W25Q20(CLIP),W25Q32(CLIP),
W25Q40(CLIP), W25Q64(CLIP), W25Q80(CLIP), W25X10(CLIP), W25X16(CLIP), W25X20(CLIP), W25X32(CLIP), W25X40(CLIP), W25X64(CLIP), W25X80(CLIP), W25P128(CLIP),
W25Q128(CLIP), W25X128(CLIP) options in <1-EEPROM&FLASH>-><WINBOND(CLIP)> (Need EEPROM CLIP ADAPTER)
+ Add XC886CM-8FFI-5V, XC886-6FFI-5V, XC886-8FFI-5V, XC886C-6FFI-3.3V, XC886C-6FFI-5V, XC886C-8FFI-5V, XC886CM-6FFI-5V, XC886LM-6FFI-3.3V, XC886LM-6FFI-5V, XC888-6FFI-5V,
XC888-8FFI-5V, XC888C-8FFI-5V, XC888CLM-8FFI-5V, XC888CM-8FFI-5V, XC888LM-8FFI-5V, XC888CM-8FFI-3.3V, XC888LM-8FFI-3.3V, XC878CM-16FFI-5V, XC878M-13FFI-3.3V, XC878M-13FFI-5V,
XC878M-16FFI-3.3V, XC878M-16FFI-5V, XC878-13FFI-3.3V, XC878-13FFI-5V, XC878-16FFI-5V, XC878CM-13FFI-5V, XC878CM-16FFI-3.3V, XC858CA-16FFI-5V, XC858CA-13FFI-5V options in
<2-MCU>-><INFINEON-XC8XXXX>
+ Add ALSVIN(2012) option in <4-IMMOBILIZER>-><CHANGAN>
+ Add AUNEAU-DELPHI-48 option in <4-IMMOBILIZER>-><CHANGAN>
+ Add VERNA(2017) option in <5-DASHBOARD>-><HYUNDAI>
+ Add K5(2015) option in <5-DASHBOARD>-><KIA>
+ Add S50(2018) option in <5-DASHBOARD>-><BAICMOTOR>
+ Add SANTAFE option in <7-AIRBAG>-><HAWTAI>
+ Add AVANTE(2017) option in <7-AIRBAG>-><HYUNDAI>
+ Add VV7-AIR-CONTROLLER option in <8-OTHER>-><GREATWALL>
+ Add MUSTANG-LEFT-DOOR-WINDER option in <8-OTHER>-><FORD>
+ Add ROEWE-PDC option in <8-OTHER>-><SAICMOTOR>
+ Add TIGUAN-HEADLIGHT-CONTROLLER option in <8-OTHER>-><VOLKSWAGEN>
Notes: please download the latest version software, any problem post here.
andresvargas704 (30th August, 2018), damih (31st August, 2018), daxxer (30th August, 2018), grzyb26 (30th August, 2018), habbyb (30th August, 2018), ibratex (30th August, 2018), keyantic (31st August, 2018), Maartinj (30th August, 2018), mobinec (1st September, 2018), sniegavirs (31st August, 2018), taxo1965 (30th August, 2018)
[QUOTE=Samic;3359569]VVDI PROG latest software version V4.7.4 update
v4.7.4 (2018-08-27)
try to semd you pm but folder is full
i manager to read now i have another problem file is 32.2 kb size . 36.0 size on disk and when i insert the file to tango says size error ..please help me experts
Sent from my SM-G935F using Tapatalk
v4.7.4 (2018-08-27)
Samic
Hi mate,the solution of honda SPC was not made same mistake...
I explain again: in the module it reads perfect, but when writing the verification it gives error...
select the type of MCU ST - SPC560P4 manually...to write 100% with verification ok
WINNER THE LOSER
ibratex (31st August, 2018)
solved thanks all mates![]()
