Page 209 of 295 FirstFirst ... 109159199204205206207208209210211212213214219259 ... LastLast
Results 3,121 to 3,135 of 4422
Thread: VVDI PROG
  1. #3121
    Jan 2013
    yes vvdi can read it both eeprom.and flash
  2. #3122
    May 2019
    nada aun pero me informare y te cuento
  3. #3123
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by marcelogtgt View Post
    Blah blah blah.....
  4. The Following 2 Users Say Thank You to sniegavirs For This Useful Post:
    alclot (13th June, 2019), castin (2nd June, 2019)
  5. #3124
    Apr 2015
    VVDI PROG latest software version V4.8.3 update
    v4.8.3 (2019-5-23)
    * This version DON't need update firmware
    * Fix STM8 option area size
    * Fix BENZ EIS-W203-1J35D(ADAPTER) can not read problem
    + Add VVDI PROG USER MUNUAL 4.8.3 version in Doc folder
    + Add R7F701103, R7F701304, R7F7013045, R7F701305, R7F701310, R7F701311, R7F701312, R7F701313, R7F701314, R7F701315,
    R7F701318, R7F701319, R7F701320, R7F701321, R7F701322, R7F701323 options in <2-MCU>-><RENESAS-RH850>
    + Add EIS-W639(2M73Y) options in <4-IMMOBILIZER>-><BENZ>
    + Add AKEWAY(2017) options in <5-DASHBOARD>-><BUICK>
    + Add K3(2018) options in <5-DASHBOARD>-><KIA>
    + Add AB12 options in <7-AIRBAG>-><BOSCH>
    + Add AB12_CB1 options in <7-AIRBAG>-><BOSCH>
    + Add GEARBOX(2008) options in <8-OTHER>-><PEUGEOT>
    Note: Please keep using latest version software, any problem post here or PM technical support.
  6. The Following 18 Users Say Thank You to Samic For This Useful Post:
    alclot (13th June, 2019), automotrizVIP (24th May, 2019), autoTkey (29th May, 2019), barho67 (24th May, 2019), damih (27th May, 2019), danielif (11th June, 2019), datapage (27th May, 2019), daxxer (7th June, 2019), Faraday (26th May, 2019), habbyb (26th May, 2019), keyantic (4th June, 2019), PocketHero (28th May, 2019), racin-snake (3rd June, 2019), rob h (25th May, 2019), sniegavirs (25th May, 2019), taxo1965 (25th May, 2019), weza247 (25th May, 2019), yui (24th May, 2019)
  7. #3125
    Usa
    Please add FRM3 9S12XTD256
    FRM Connection
  8. The Following 11 Users Say Thank You to hojo25 For This Useful Post:
    aone222 (27th May, 2019), barho67 (26th May, 2019), datapage (27th May, 2019), Faraday (26th May, 2019), neuro (26th May, 2019), Perryking (27th May, 2019), plamen 63 (8th June, 2019), PocketHero (28th May, 2019), rob h (26th May, 2019), sniegavirs (31st May, 2019), weza247 (27th May, 2019)
  9. #3126
    anybody test on x250 bcm, listed under immo - jaguar- xf-rfa
    after reading ecu is dead, write verify all ok but ecu no longer has can bus alive
  10. #3127
    Sep 2014
    Quote Originally Posted by phatty123 View Post
    Are you read bcm or rfa (kvm)?
    I read bcm from range rover without problem. And i read many kvm without problem. What bcm do you have?
    Wysłane z mojego SM-G389F przy użyciu Tapatalka
  11. #3128
    Quote Originally Posted by jkoli View Post
    It 's BCM, in vvdi it is listed as RFA but it's really BCM even in picture it says BCM in the middle of the PCB. This is new added in 4.8.1 I also did BCM/CEM without issue this is one is different though. Take a look in the software under Immo-jagaur-xf-rfa(2013)
  12. #3129
    Jul 2012
    Xhorse VVDI Prog 35160DW Chip Replace M35160WT Adapter
    this chip not work or have problem read and write
    i read chip and all lines zero
    i write the original dump but stiil all lines zero
    any one work with this chip before.
  13. #3130
    Moderator
    PremierD's Avatar
    Jun 2009
    Worked perfect for me ..........
  14. #3131
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by 1704E3 View Post
    In your first sentence, last word... adapter...
    what kind of adapter you talking about...?
  15. #3132
    on mc9s12 adapter what is 5+? VCC? red cable?
  16. #3133
    Jun 2016
    hello everyone any member there could i help my vvdi prog of nowhere stopped recognizing the device more
  17. #3134
    Jun 2016
    last update ... device error please check usb driver ... already made everything else windows pc outo cable install driver and nothing ever this error
  18. #3135
    In EEP
    Mercedes W639 EZS MCU R1(odometer)
  19. The Following User Says Thank You to vasa For This Useful Post:
