Page 232 of 295 FirstFirst ... 132182222227228229230231232233234235236237242282 ... LastLast
Results 3,466 to 3,480 of 4422
Thread: VVDI PROG
  1. #3466
    igorr's Avatar
    Aug 2010
    Maybe to tray to program vvdi prog driver vith mprog
  2. #3467
    alclot's Avatar
    Melee Island
    Quote Originally Posted by lidons View Post
    same problem as @alclot
    I also have problems with Port-USB, there is no communication with vvdiprog, checked on several computers,
    the computer recognizes in repainting and installing that it is a VVDIprog machine, but there is no way to synchronize with any port.
    * I finish reading a DASh Ford focus all ok, reading and writing, and to read another EEP different 93c56 of a fiat and the vvdiprog is dead.
    I have changed the USB 2.0 Connectors type B Jack vvdiprog and there is no.
    internal VVDIprog battery, it's ok 3V
    any suggestions?
    Hi mate. Exactly the same problem I have. I tried to contact with the chinisse seller but he is triying to cheat me asking me things with no sense. I hate that. When you sell anything you have to give support and warranty. Maybe anyone can help us because I’m sure is a common problem on this programmer.
    Thanks a lot
  3. The Following 2 Users Say Thank You to alclot For This Useful Post:
    barho67 (18th March, 2020), Meat-Head (8th March, 2020)
  4. #3468
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by alclot View Post
    Thanks a lot
    Don’t blame Chinese sellers...blame yourself...we always get what we pay!!!
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  5. #3469
    Thanks a lot
    You need to send it back to China for repair. Contact Samic or Perry if you have issues with your dealer.
    You have either HW error or SW from STM32 got corrupted.
    Nothing you can do or repair by yourself.
  6. The Following User Says Thank You to exe123 For This Useful Post:
    alclot (8th March, 2020)
  7. #3470
    alclot's Avatar
    Melee Island
    Hi man. I dont blame chinesse sellers just I hate when the sellers dont give support aftersales doesnt matter where they come from. Sorry If the post looks like that
    Quote Originally Posted by bearheroes View Post
  8. #3471
    lidons's Avatar
    Feb 2011
    @exe123
    that's right, it's an error of STM32F407
    if the 3v battery expires or the broken terminal is broken, it will not keep the energy and the info is also corrupted, just like AVDI
    it would be better if they sold that loose memory to weld, sending machine is an extra expense and time wasted unnecessarily.
    excuse my English, is the best.
  9. The Following 3 Users Say Thank You to lidons For This Useful Post:
    alclot (8th March, 2020), barho67 (18th March, 2020), lock66 (8th March, 2020)
  10. #3472
    Oct 2015
    Hi, I tried to read without succes PSA EDC17C60 with bosch cable adapter and latest version software. I can't do it, anyone can confirm if there are any problem with this ecu?
  11. #3473
    Dec 2010
    Quote Originally Posted by Perryking View Post
    Yes friend I read a few days ago.
    Good luck
  12. The Following User Says Thank You to jaelgti For This Useful Post:
    sqlkarol (21st April, 2020)
  13. #3474
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by jaelgti View Post
    Good luck
    you has read it it with boot pin...
    @Perryking tried it with Bosch ECU Adapter like Servicemode, without opening...
  14. #3475
    Default MC9SDP512 !L00M mask reading
    Hello try read this MCU but it fail i tryed first when it was connected on pcb was on Ford BCM but it did fail so i unsoldered and use reading board i connected as it says on instructions pin 107 VSS pin 14 gnd pin 23 BKGD and pin 42 Reset but ID fails 01 is there any other connection for this because if you check other readers they give bit different points like UPA and Xprog
  15. #3476
    Oct 2015
    Quote Originally Posted by figani View Post
    Yes, I tried to read only with Bosch ecu cable and didn't work. With boot pin I readed with Ktag.
  16. #3477
    CROATIA
    NEW VERSION
    VVDIProg4.9.2
    https://mega.nz/b1062cd6-d775-4149-a007-5123251b477c
    v4.9.2 (2020-03-16)* This version DON't need update firmware
    + Add VVDI PROG USER MUNUAL 4.9.2
    version in Doc folder
    + Add STM32F405RG,
    STM32F405OG,
    STM32F405VG,
    STM32F405ZG,
    STM32F405OE,
    STM32F407VE,
    STM32F407ZE,
    STM32F407IE,
    STM32F407IG options in
    <2-MCU>-><ST-STM32>
    + Add FRM-E-SERIES-XEQ384-READ,
    FRM-E-SERIES-XEQ384-WRITE,
    FRM-F-SERIES-XET512-WRITE options
    in <8-OTHERS-><BMW>
    + Add ENVISION—TAILGATE-COMPUTER
    options in<8-OTHERS-><BUICK>
    + Add PHAETON—TAILGATE-COMPUTER(2012)
    options in<8-OTHERS-><VOLKSWAGEN>
    If my post was helpful, click the Reputation and Thanks buttons
    X-TOOL, BESTDIAGCAR2014, DP3, GALLETTO V54, KESS V2, KTAG, FVDI2018, NEO X, VVDI prog, VVDI BMW ALAT, VVDI2,IDS MAZDA-FORD, iPROG+, AUTOOTUNER MASTER,MAGICMOTORSPORT FLEX MASTER,KEYMASTER,AUTEL IM608PRO
  17. The Following 4 Users Say Thank You to brane0001 For This Useful Post:
    amaflo (25th March, 2020), habbyb (26th March, 2020), KADE007 (23rd March, 2020), PocketHero (23rd March, 2020)
  18. #3478
    Ukraine
    BMW EWS4 ruined it eeprom.Not write.
  19. The Following User Says Thank You to Botos Leonardo For This Useful Post:
    KADE007 (26th March, 2020)
  20. #3479
    Oct 2018
    Macedonia
    Same here, I would like to read this flash M58BW016. But only option is the reading over adapter. Is there any bdm reading for VVDI prog?
  21. #3480
    Jul 2018
    Can Vvdi Prog Clone UCH DACIA DUSTER 2018 If Can Please Show Me The Wiring
