What is the correct description of this size eeprom. I need to get 24C16 but unable to accurately search for it.
Sent from my SM-G930F using Tapatalk
MSOP.....package............for TLFE eeps ...Tiny ..Little ..F cukin ..Eeproms ..![]()
rafal (18th December, 2021), trinicolin (18th December, 2021)
Hello everyone, trying to IMMO OFF on a 2002 vw beetle ME7.5. I have two problems. One is that the option to immo off eep is 95080, mine is 95040, and the second issue I have is how it is done. What are the steps. I read, and did the immo off, but I see another button for swap bytes, do I have to do anything with it? I have done this procedure on the car no problems. But here I have the option for BYTE SWAP. Your help would be appreciated
I need to update my vvdi prog. It recognizes usb port, but does not blink the led to start. Any help would be appreciated thank you
Hello friends. Today, for the second time, the VVDI prog has destroyed the flash and the processor 1n35h . First time, 2 month ago a 2017 Porsche 911. I read D flash and P flash, returned it to the car. silence! only the relay in the BCM clicks. compared my P flush to a friend's P flush, a large piece is damaged. I had to re-solder 1N35H, because the native chip could not be erased or written. and write down my D flash and a working P flash of a friend. at that moment I thought it was my mistake. BUT!!!
Today I read the Porsche Panamera in the backup only D flash and returned the unit to the car. Again ominous silence, and only the relay in the BCM clicks. Again, I removed the BCM, read the P flash, and quickly bought the P flash from the working block on the Internet and compared it with 911. Not the entire P flash is destroyed, but a certain piece. and after when you due unlocking, the chip says done, but when i want write fix P flash writing crypt. again a chip for replacement ( how fix this bug?
Only with reading dflash backup the tool destroy bcm?i think its unsafe tool
Sent from my SM-A125F using Tapatalk
immoneard (7th March, 2022)
v5.1.0 (2021-12-31)
https://mega.nz/file/8MVynDrD#Q6H1FEwZal9kGXIx4Fpk3aCbg0TQz3jhXGmp8grV1 Fw
* This version DON't need update firmware
* Fix M95010, M95020, M95040,options in <1-EEPROM&FLASH>-><ST>
* Modify LOCK_BCM2-1(ADAPTER),LOCK_BCM2-1(WELD),LOCK_BCM2-2(ADAPTER),
LOCK_BCM2-2(WELD), options in <4-IMMOBILIZER>-><AUDI>: Optimize the process
* The default voltage of options about MC68HC(9)08 change to 10.5V
+ Add CAT93C86[B] option in <1-EEPROM&FLASH>-><CATALYST>
+ Add PCA8581, PCD8582, PCF85116, PCF8582, PCF8598 options in<1-EEPROM&FLASH>-><PHILIPS>
+ Add S-93C46BD, S-93C46BR, S-93C46C,
S-93C56BD, S-93C56BR, S-93C56C, S-93C66BD,
S-93C66BR, S-93C66C,S-93C76BD,S-93C76C,
S-93C86BD, S-93C86C options in<1-EEPROM&FLASH>-><SEIKO>
+ Add TC97101 option in <1-EEPROM&FLASH>-><TOSHIBA>
+ add MB91F249/S, MB91F264,
MB91F272, MB91F312, MB91F346,
MB91F463NA, MB91F463NC, MB91F464A,
MB91F465B, MB91F465D, MB91F465K, MB91F465P,
MB91F465X, MB91F467B, MB91F527, MB91F528,
MB91F552, MB91F583, MB91F584, MB91F585AM/AS,
MB91F585L, MB91F586L, MB91F587L, MB91F625,
MB91F635A, MB91F637, MB91F637A, MB91F639,
MB91F639A, MB91F644, MB91F644A, MB91F647,
MB91F647A,MB91FV310:FONT, MB91FV310:PROG,
MB91FV319A:FONT, MB91FV319A:PROG,
MB91FV319R:FONT, MB91FV319R:PROG, options in <2-MCU>-><FUJITSU-MB9XF>
ASCM (5th January, 2022), danielif (15th January, 2022), dawidhubert (4th January, 2022), KADE007 (31st December, 2021), lion0304 (1st January, 2022), mecadriano (5th January, 2022), PremierD (31st December, 2021), scotlock (31st December, 2021), ThiagoArgentino (5th January, 2022), trinicolin (2nd January, 2022), ttzag (18th January, 2022)
For correct operation, VVDI PROG must determine the chip ID. For 1N35H ID:CC95
You have everywhere ID: FFFF and accordingly, the chip is not unlocked. That's why you can't program it.
For Porsche vvdi prog is not good solution! This is a 50/50 lottery game.
Developers don't solve problems for BCM Porsche and it's upsetting
miroopel (3rd January, 2022)
Hello, I am trying to clone this BCM of Ford Fiesta 2020, I read the old Renesas vh-850 with VVDI, all was ok, made backup to the new one files and wrote the c-flash, but when tried to write d-flash there is error, no way to write it. There is an error on erasing or at writing start. MCU is R7F701053, Now, can read only ID and Security bit, I dont know whats wrong help or suggestions are welcome, thanks.
Hi does anyone tried to program porsche cayenne third generation read bcm with vvdi prog and program key with vvdi 2
Correct me if I'm wrong, but I don't think it's possible with any tool yet - as it is MLB EVO platform.
