ec17c50 is read ok....................
read ecu bench and post files if don't need risk
need help
now my goal is to buy xp-005
who will help?
How did you solved steps...
Sent from my SM-A125F using Tapatalk
I'm try to repair an mb citan instrument cluster,which have corrupted flash.
Flash are MB96F386RWB
Connected vvdi prog as it's connection diagram,but always:read error 00
Some hints?
v5.3.3 (2024-01-24)
>>download<<
* This version DON't need update firmware
* Some ECU options process optimization
* Land Rover RFA Adapter options process optimization
* RH850 series Some options wiring diagram updated
* Modify LOCK_BCM2 options in <4-IMMOBILIZER>-><AUDI>:Erasing failure repair and prompt message modification
* Modify CAVALIER(2018) option in <7-AIRBAG>-><CHEVROLET>: Wiring diagram update
* Modify LITHIUM BATTERY MODULE option in <8-OTHER>-><Porsche>: Wiring diagram update
dawidhubert (24th January, 2024), rob h (25th January, 2024), sniegavirs (23rd January, 2024), teerak2uk (23rd January, 2024)
Maartinj (24th January, 2024)
You could make a folder exception, from you virus scan sw.
You think, Big Brother is watching you al the way from China?
It checks for updates,
A active program, Chinese origin. It will raise some flags.
But yes, vvdi2 is ok, atleast lately.
So, they might fix it, with the new programmer?!?
Landrover RFA secured XEQ384 adapter - still not working
