Hi.
Does anyone on the forum have a working diagram?
To VVDIPROG
Airbag volvo V40 XC2361A-72F
P31406254
T131151170122
Thanks in advance.
Hi.
To VVDIPROG
P31406254
T131151170122
Thanks in advance.
Have a look a :
https://www.digital-kaos.co.uk/forum...vo-V40-Xc2361A
Maybe this wil help you
dawidhubert (14th October, 2024)
Thanks but this connection doesn't work.
It reads 98% and ERROR
v5.3.7 (2024-10-18)
>>>DOWNLOAD<<<
* This version DON't need update firmware
* Fix reading ECU communication failure
beltronics (20th November, 2024), dawidhubert (26th October, 2024), mikajna (18th October, 2024), rtbdiagnostic (18th October, 2024), Weasel3 (18th October, 2024)
https://www.vvdishop.com/service/xho...N2JrOIiL5QHG8G
Anyone tried to replace the battery of vvdi prog and was successful? Says must be down while powered on
fuzz1 (21st October, 2024), rtbdiagnostic (21st October, 2024)
I want to replace the battery before it goes flat and the unit useless. So I found this post but not too sure how to go about replacing the battery in a preventative way to avoid ending up with a flat battery
It is all written in that post. That is why it exists.
I plan to replace the battery.
For this:
- solder a socket from an old PC motherboard for the CR2032 battery and solder it to the battery contacts CR2354 on the VVDI board(where CR2354 soldering will not be performed)
- insert a new CR2032 battery into the socket (parallel with CR2354)
- solder out the old CR2354 and solder in the new CR2354 (at the same time, the CR2032 will hold 3V for the VVDI board)
- remove CR2032 and unsolder its socket
Using external power supply is way more easier. If you are that scared add USB cable power as well. That additional battery socket could make it more problematic..
fuzz1 (24th October, 2024)
Returning to the topic of the infineon XC2361A 72.
I decided to check.
Is the MCU Reflesh V3 cable that I have really V3.
After disassembly, you can see that it looks like V2, only a different color of the board.
And these two resistors are installed where they should not be in the V3 version.
Can someone more experienced comment on whether my cable needs to be modified?
I wrote about replacing the battery a dozen or so topics ago.
In my case, I powered it via USB.
You have to do it carefully so as not to short circuit it and make sure that the programmer is not deprived of power.
I would suggest using an external power supply.
Because the computer's USB will turn off the voltage when it is overloaded.
rtbdiagnostic (1st November, 2024)
FUJITSU MB90F347CA ERASE ERROR (00)
Read file its no problem, but when I try to Write new file,always same error, I cant erase and write file
