Results 1 to 12 of 12
    Jul 2011
    Default Fiat Panda Power Steering
    I feels like the torque sensor is failing or not calibrated on my panda 2009.
    It is easier to turn left than right when the car is moving.
    I will look at checking with MultiEcuScan. If I cannot reset I will buy a new sensor. Do i need the above tool to calibrate it?
    I saw this video that shows calibration - looks straightforward with the tool...
    Any advice on what I should try first?
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    no friend, the sensor is calibrated with a diagnosis !! I changed two sensors per day !! never bought test sensors, use Texa
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
  3. The Following User Says Thank You to centrohifi For This Useful Post:
    rudidudi (16th June, 2015)
    Oct 2013
    Quote Originally Posted by rudidudi View Post
    If you have uneven torque like you said put the wheels straight and just do a calibration with the MultiEcuScan with only ignition on.Do this also on CITY.this will balance the torque on right and left.If the MultiEcuScan shows a torque fatal error you buy the torque sensor with the Zero clip in place and you must put it in carefully to be in this position otherwise you won't be able to calibrate it
  5. The Following User Says Thank You to sunxemx For This Useful Post:
  6. #4
    Jul 2011
    Quote Originally Posted by centrohifi View Post
    I havent heard of Texa.. is a 'home' version available?
    Quote Originally Posted by sunxemx View Post
    Yes I saw that MES has a calibration function. I have ordered the coloured adapter leads which I expect to receive today, hopefully.
    Any hints on how to carry out the text and calibration with MES? Is it just stationary with wheels forward? I saw on MES that there is a procedure where you need to drive iirc 30kph... what is that about?
    Oct 2013
    No just do the calibration with the wheels straight (ie steering wheel dead straight) ignition on engine off.Just do it in the garage.Do all the calibrations then after test with engine on.Thats it. I have done hundreds like that
  8. The Following User Says Thank You to sunxemx For This Useful Post:
  9. #6
    Jul 2011
    Thanks sunxemx,
    The ones that you have done, have some also been the same symptoms as mine, i.e. when driving you feel more resistance turning in one direction than the other?
    I was meant to receive the MES adapter leads today but they didnt arrive. Can you tell me where the socket is to plug in the adapter lead?
    thanks again!
  10. #7
    with MES or other diag you will not solve the problem,
    becouse you can reset only the 'Position' but no torque.
    Hope helped
    B Regards
  11. The Following User Says Thank You to scs-mem For This Useful Post:
    rudidudi (17th June, 2015)
  12. #8
    Oct 2013
    Thanks sunxemx,
    thanks again!
    Yes same symptoms on RH drive cars its under steering wheel on the right side, on LH drive I am not sure, probably same on the left under steering wheel
  13. The Following User Says Thank You to sunxemx For This Useful Post:
    rudidudi (22nd June, 2015)
  14. #9
    Oct 2013
    Quote Originally Posted by scs-mem View Post
    Hope helped
    B Regards
    I think you are mistaken my friend
  15. #10
    And then if is so,
    why has been invented the tool?
    You can reset all only in fiat punto 188(with diag i mean)
    B Regards
  16. The Following User Says Thank You to scs-mem For This Useful Post:
  17. #11
    Jul 2011
    Thanks for the replies guys.
    The MES adapter cables arrived and i did different diagnostics and resets
    Unfortunately it did not change the feeling of the steering.
    I reset the torque sensor and position calibration but no difference. The car self centers more when steering right.
    With MES I discovered a couple of things:-
    1. the center of the steering position seems to be in the middle of the rack. By going full lock to full lock the 0.0 degrees is in the middle of the full lock.
    2. One of the settings 'current absorbed' shows 'too high'.
    Could the 'current absorbed too high' mean the steering self centers more in one direction, or is this a different issue?
    What should I do next?
  18. #12
    what other repair exist to these cars except steering sensor when they have defective unit or defective motor?
    i have one of these that works ok and when i open blower motor the steering stops..
    and an other that have always fault code for motor..
    what might it can be?
    thanks in advance
