    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Cloning UEC Vectra C
    I am trying to clone UEC from Vectra C, i copy 95040 eeprom, but with new UEC the car doesnt start. immo data are stored in this Eeprom or i am wrong?
    norfolk uk
    I have changed this without any coding, don't think this unit are coded on vectra
    Bllinda's Avatar
    Baltic
    Where is tethered .... Get Up original donor damp.
    Quote Originally Posted by ruffles1986 View Post
    today
    A topic that interests me
    Sep 2011
    In the Garage
    The car is vectra c from 2005, i changed also this unit without coding anything in vectra C from 2002 (old radio type, not cd30) but the mechanical said me when he install new module(from scrapyard) he has comunication with uec, but steering and lock led go on in dash. Then i thinking copying 95040 eeprom copy all configuration from car and immo data( if have it)
    Shmortz's Avatar
    in the middle of nowhere
    you need to reset donor UEC and reprogram it using original car PIN and configurations...
  6. The Following User Says Thank You to Shmortz For This Useful Post:
    ruffles1986 (26th June, 2015)
    Bllinda's Avatar
    Baltic
    with tech programming will require the s.p.s and p.i.n.
    today
  8. The Following User Says Thank You to Bllinda For This Useful Post:
