try to another laptop..
cerco firmware per galletto v50,
qualcuno può aiutarmi?
grazie
I am looking for firmware for galletto v50,
can someone help me?
[QUOTE = joker01; 3521855] désolé les gars ...
quel fichier dois-je utiliser pour flash ????
d'après ce que j'ai compris ??? dtr qu'est-ce que c'est ??? [/ QUOTE]
the dtr is the pin of ftdi232 (only for control no used) you can use file with dtr or without dtr ,all files is same
Unfortunately no. Mine is like this https://www.digital-kaos.co.uk/forum...4&d=1356199044
As you can see, it has 11 legs for connections...
Dont spend your time with prehistorical tool which can damage your ecu...
Much better kess and k-tag.
XJTAG (30th November, 2019)
Thanks bro ..![]()
Hello guys - does anybody have FGtech software 2014 V54 or 2017 V54 - for V0475 ?
I connect LPC2119 on VD300 as in second picture - only RX an TX connection with programmer and wire jumper with ground on PCB.
Everything is ok and my VD300 is V475 now and working fine.
PatricioPanama (24th June, 2020)
The new china FG Tech 0475 working perfekt on Windows 10 64 bit, although they give it for Windows XP and Windowd 7 32/64 bit.
FGTech Galletto, chinese copy.Does anyone know what this element is, marked with U2 in the picture.The device stopped working and I noticed that this part is very hot.Pin 1 is 0 volts and pin 3 is 3.3 volts.I removed the element and measured only 20 Ohms between pins 1 and 3.The device sometimes works, but I have to turn the USB cable on and off 30 or more times.If anyone knows please help me.
What markings are on it?
Unfortunately I can't read
