Results 1 to 8 of 8
    Dec 2013
    Africa
    Default Toyota Hilux Vigo 2008 ( Thailand ) Remote Programming Procedure Required.
    HI Every One.
    i try to Program Remote for toyota Hilux Vigo Thailand Make but Car is not turning to Auto Mode,
    i try with T Code and T300 but Commuinication Failed. try to Programe Manually normal Toyota Remote Programming Procedure but not Success yet.
    any body know a Instruction ????
    this remote Comes With The PAIC Button.
    ray-ray's Avatar
    Try remote section on the tcode or mvp under type 4
    Dec 2010
    thailand
    TOYOTA VIGO Thailand Remote Programming
    1.-Close the diver door , insert key in to ignition & wait for 5 seconds.
    2.-Turn On and Off ignition 5 times, ON 5th tines keep it on position.
    *************LED becomes stable*********
    3.Open and Close door 1 time and turn OFF the ignition.
    ******Sound beep *******************
    4. Open the door and turn ON, Close the door and turn the ignition key to ACC .
    5.-Press Lock & Unlock button on the new remote together to match it to car. [door close]
    '******wait until Sound beep *******************
    Check the new remote for working.....Finish
  4. The Following 6 Users Say Thank You to Krittanu For This Useful Post:
    Carsoft2003 (12th November, 2016), cjawahir (21st September, 2015), kyawkyaw (21st September, 2015), polys123 (22nd December, 2016), Roy Suryadwiananda (19th May, 2016), weza247 (5th July, 2016)
    Sep 2015
    myanmar
    Thumbs up NEED TO HELP FOR TOYOTA PASSO SMART KEY PROGRAM ADD KEY
    HELLO, PLEASE HELP ME SOMEONE, HOW TO PROGRAM TOYOTA PASSO CAR KEYLESS REMOTE SMART KEY, PLEASE HELP ME ALL MY TEACHER
    THANK YOU VARY MUCH ALL MY TEACHER
    Last edited by kyawkyaw; 21st September, 2015 at 10:28 AM. Reason: EDIT FOR TAG TITAL
    Apr 2014
    Any added information on this topic? I got a 2008 Toyota hilux that I am trying to add the remote but without success. I've tried the above procedure also the two online. Not getting the system to enter the Programming mode. I surely need the assistance of you guys.
    Sent from my SM-G930F using Tapatalk
    KriptoKey's Avatar
    Feb 2012
    If the manual procedure is doing correctly, the problem is the remote you are using. use a good quality remote control.
    luck
    Apr 2014
    Quote Originally Posted by KriptoKey View Post
    luck
    Not even getting the van into Programming mode.
    Apr 2014
    Quote Originally Posted by trinicolin View Post
    Ok guys. The procedure is correct. The ON OFF cycle must be done within 3 seconds. The rest of the procedure went smoothly. Thanks much.
