Results 1 to 15 of 17
    davecooper47's Avatar
    Dec 2010
    Default Bosch ME7.1.1 dEAD
    I was remapping a Bentley Continental GT 2006. Programmed Master ok but slave crashed at 8%. I can't get any communication with the ECU at all. I have found a second hand ME7.1.1 but the part number is slightly different. My question is: If I program the 29f800 flash data and the eeprom 95160 data from the dead ECU to the donor, will it work?? Thanks. Dave.
    Do you still have the original 29f800 and eeprom before you tried programming it? If so then probeblay will work if there both me7.1.1 even with a different part number
    Dec 2010
    I have the original 29f800 but didn't take read of 95160 until after damage was done. 95160 doesn't get touched does it??? When I try to connect with Kess now, it says "error finding hardware ID" or something like that.
    I've just read the EEprom data and I can see the VIn and part number in the ASCII column very clearly. Should I believe that if I swap this data the replacement ME7.1.1 will become that part number? Also, where is key data??
    Nov 2011
    Write only 29f800 in programmer with ok file .... You dont need new ecu .
    Dec 2010
    I need to replace ecu. It was spiked. It will not power up.
    Dec 2010
    Got the Slave ECU back to life. I copied the master ecu eeprom data (95160) into the slave and now I can communicate with it and get hardware ID etc but it won't start and if I try to reflash original files with kess I "get checksum error". When I read flashes again with Kess, at the end of read I can save the data but it says "checksum error" also. Attached are the 95160 eeprom from master (which I presume is ok because it programmed ok) and 95160 from slave which I presume is corrupt because I couldn't communicate with this data in eeprom and the slave is what I was programming when it crashed..
    Feb 2013
    The immobilizer data (that must match the key/cluster/immo box if so equipped) is stored right after the login code.
    It's sufficient to copy 0x30 to 0x3F and the backup page 0x40 to 0x4F into the new eeprom to establish immobilizer authentication.
    As for the damage, your ecu is stuck in programming mode. The eeprom stores this condition. I can patch the routine that checks this to bypass the entire function. I need your original flash files. Post them, or email me.
    I have only ever done 07C906018DF 379143, I do not have your original file.
    myusername at google mail dot com
    Dec 2010
    Files attached. Please can someone help me with this. Customer supposed to be doing a wedding this afternoon. Thanks. Dave.
  9. The Following User Says Thank You to davecooper47 For This Useful Post:
    bendy (10th October, 2024)
  10. #9
    Dec 2010
    Ok. So it seems me slave ECU is stuck in programming mode so I can't get communication. Does anyone know how I can release it from programming mode please.
  11. #10
    Feb 2013
    This is a later ST10 ecu. Not standard C167. At this point your best bet is to successfully program the ecu. Either via an OBD read or write.
  12. #11
    Dec 2010
    Any advice on how to program it. Only thing I have for this is VCDS. Thanks. Dave.
  13. #12
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    try in boot mode
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  14. #13
    Feb 2013
    Bootmode won't help. The ecu needs to complete a read/write operation so that the eeprom clears the programming mode data.
  15. #14
    Jul 2011
    Bulgaria
    Why not desolder flash put on programmer for sefty.
    In my own opinion to now is better to desolder when you have flash likes 29f put on programmer and read write then solder to ecu.
    Loose 30 minutes but now you cane loose many days to revive the ecu and car with ori files and go away !
    My advice go to dealer and make update from ecus..
  16. #15
    Feb 2013
    Quote Originally Posted by k1champion View Post
    This is not going to help, and it's unnecessary. If he had read the eeprom and flash, the ecu would be functioning.
    To be safe, these ST-10 ecus should be done in boot mode, and have everything backed up prior to flashing.
