Results 1 to 5 of 5
    drpeter's Avatar
    The Netherlands
    Default corsa d service reset with code
    Customer wanted a service reset on 2 corsa's D (2012 and 2013) after km adjustment but his cards where missing (code), i took fvdi could and read the code under ''display info'', all other security code options did not work. with the code i could reset the service, just want to let you know. I could not find a reset service option in fvdi though.
  2. The Following User Says Thank You to drpeter For This Useful Post:
    HeXeN (4th November, 2017)
  3. #2
    Aug 2012
    outerspace
    I think you only need button on dash to resset services
    Option in istruments is only change duration (using security code)
    Push reset button on odometer then keep brake pedal pressed untill the ---- start to flash and reset done.
    Dont know how to reset insp2 on corsa does anyone
    smokey08's Avatar
    Essex, UK
    I serviced a 2013 1.6 turbo corsa d and I had to use the security code to reset the service light.
    Insp2 is probably a bulb blown.
    Mar 2011
    open dash
    read m35080
    use help from jpg
    yu have pin for dash
    open opcom end do reset :P
  7. The Following 2 Users Say Thank You to killer85 For This Useful Post:
    corsahunter (20th November, 2017), drpeter (17th July, 2015)
