Results 1 to 15 of 25
    Default Suzuki Grand Vitara 1.9DDiS edc16C3 P0638 dtc off and limp mode
    Hello. Patient Suzuki grand vitara 1.9ddis edc16c3 0281015322.
    Car was in limp mode, one dtc stored in ecu P0638 - throttle position actuator.
    I switched off this dtc, after that no errors but car is still in limp mode.
    Anybody has experience with that situation?
    I read that I have to edit limp mode torque limiters.
    What will be with boost regulation valve N75 after that operation? Now it doesn't move the bar.
    Can I get any advice or help with switching off this swirl flap?
    Thank you all for interest.
    Magicmotorsport Flex Full, Magpro2, Swiftec, Winols, full ETL, Carprog and others....
  2. The Following User Says Thank You to atd For This Useful Post:
    lokher (20th May, 2017)
  3. #2
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Sure we experience, and solution is easy,
    Don't DTC off for throttle actuator This is not EGR, actuator needed work, sure can remove limp mode for it but this is not solution to repair car problem..
  4. The Following User Says Thank You to CustomCars For This Useful Post:
    teamtuner (25th July, 2015)
  5. #3
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by CustomCars View Post
    good english used mate...i hope to understand all members this...tuning is not for reppair cars...is for more performances
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  6. #4
    Jun 2013
    EU
    Nah! is better and cheaper try to hide the problem than spend some bucks in get the spares and repair
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    here you go mate
    pass pm
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  8. The Following 6 Users Say Thank You to boomeer For This Useful Post:
    atd (27th July, 2015), ipsoftw (26th October, 2016), khaleddaddi (19th December, 2017), lokher (20th May, 2017), rudiniiwwa (15th December, 2016), Tzepy (3rd September, 2019)
  9. #6
    I will try boomer file. Owner decided to delete problematic element from car. Many people have problems with flaps in 1.9ddis, you have to make adaptation with tech2, used flap could also be not as good as new one ( not so cheap ).
  10. #7
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    please tell us for what in diesel engine throttle is so much needed?
  11. #8
    Newbie VegaWorks's Avatar
    May 2015
    Italy
    Check that has not gone water in the throttle actuator, Suzuki has introduced a cover for this component, the OEM Code is 13471-67J00-000.
    Sorry for my bad English *_*!
  12. The Following 2 Users Say Thank You to VegaWorks For This Useful Post:
    pinotec (26th July, 2015), teamtuner (26th July, 2015)
  13. #9
    Problem solved, car runs fine, thanks all for input. Big thanks to boomer.
  14. #10
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    @boomeer Yes is needed for diesel too. One of all function is protect engine.
    Swirl no needed, but throttle is quite another story
  15. #11
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Yes his need to stop engine ..... and that all or better say his helps stop engine when engine don't want stop
  16. #12
    amrif's Avatar
    EU
    Quote Originally Posted by boomeer View Post
    Throttle is an essential part of a safe car.
    If the engine goes into so-called "runaway", that is, it suddenly gains insane amount of revolutions per minute, the throttle won't stop it (because you turned it off permanently). If your car uses automatic transmission, without the throttle you have literally no way of stopping it. Except for, maybe, blocking the air intake, but it's highly possible that you won't manage to do that in time. If you have a manual gearbox you can try setting your highest gear, then pressing the brake and releasing the clutch, such action may stop the engine as well.
    If you don't stop the engine runaway in time it will most likely blow up your engine.
    Visit this site if you want to learn more about engine runaway:
    https://www.carthrottle.com/post/9liEWT/
  17. The Following 2 Users Say Thank You to amrif For This Useful Post:
    bobolin4o (24th August, 2016), oem (24th August, 2016)
  18. #13
    kazikk's Avatar
    here you go mate
    pass pm
    can you remove limb mode for me.
  19. #14
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Quote Originally Posted by kazikk View Post
    here you go pass pm
  20. The Following User Says Thank You to boomeer For This Useful Post:
    kazikk (8th September, 2016)
  21. #15
    dimitar's Avatar
    [QUOTE=amrif;2834022]Throttle is an essential part of a safe car.
    Nice write up mate but throttle wont save you if you shift wrong gear
    or if turbo blows and fills the engine with oil
    The first aplication of the throttle was a anti judder valve
    Lately became a part of the regeneration process , now a safety valve.....
    It was always a part of conspiracy for automotive companies making money........
    50w Soldering Iron
    Chisel
    Sometimes Hammer
