Results 1 to 2 of 2
    Nov 2012
    Default Berlingo BSI Reset help.
    Dash manufacturer is Jaeger, BSI is made by Siemens
    Dash chip type is 95020, in BSI is 95160.
    I'm correcting the mileage on the vehicle and I've done the dash using tacho soft already but I can't find which type the BSI unit is as in tacho soft is showing me 3 types in order to reset it so it can take the new mileage straight from the dash.
    Is there a way to determine BSI type as I don't know where to put the F's ?
    Thank you
    Oct 2015
    argentina
    Default bsi okm
    Restablecer ah 0 kilometros probala y espero las gracias
