Results 1 to 12 of 12
    Sep 2012
    Default peugeot 407 1.6 hdi 2006 code P0243
    Hello fellow got this error in this car and not open and does not have the turbo power loss
    p0243 pressure control solenoid valve turbo
    I can not erase is dtc
    that can happen companions can help me thanks and regards
    check the turbo electrovalve..it may need replacing!
  3. The Following 2 Users Say Thank You to ominimicu For This Useful Post:
    hackbest (27th July, 2015), nenadrossi (27th July, 2015)
    Sep 2012
    I about 5 months ago became new.
    as I can check?
    Sep 2012
    I think it is this piece that does not come down at all
    this valve when it started the car should butt down and not low
    that is the turbo actuator, works with vacuum. i usually suck with my mouth and hold air with toungue to see if it leaks. u can also apply a direct vacuum hose and car should have a lot of power but will enter limp mode cause of too much pressure.
    to a vacuum test on it see if it holds air!
  7. The Following User Says Thank You to ominimicu For This Useful Post:
  8. #6
    Sep 2012
    I did a test vacuum valve and loses
  9. #7
    Great then replace iT!
  10. #8
    Sep 2012
    that does not lose
    I checked into another car and works well
  11. #9
    u just said it loses!
  12. #10
    Sep 2012
    do not
    loses
  13. #11
    then check to see if u get vacuum over the vacuum hose that plugs into that!
  14. #12
    Sep 2012
    it does not work.
    It may not be the ecu?
    BDM will have a new office and check
