Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    Above sea-level
    Default BMW Siemens MS42 immo off
    Can someone immo off MS42 or tell me how to connect an ews emulator to a MS42 ecu?
    Is it possible to read the sync code from the flash?
    Jul 2011
    I?m currently working on MS42 ews delete and will publish it when ist finally tested
  3. The Following 5 Users Say Thank You to Cloudforce For This Useful Post:
    1gcrazy (4th January, 2017), acmotor (10th August, 2015), kugglefischer (22nd October, 2019), mexanico1971 (4th November, 2015), yanni8 (27th December, 2015)
    Above sea-level
    I have installed an ews emulator, but somehow it does not work yet. Have programmed the ISN, connected the emulator to the ews line, bridged ews connector starter motor connections and removed the jumper, but car still does not start. :-(
    Above sea-level
    is there a difference between EWS3 and EWS3.2?
    bram380's Avatar
    Indonesia +628153111774
    easy methode is transfer dme isn into ews.
    Above sea-level
    There is no ews with this car anymore. The car is just for racing. Can someone tell me which ISN it should have?
    Ecu is 5WK9037 7500255 MS42
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Quote Originally Posted by budG60 View Post
    ISN is: 8D48
  9. The Following User Says Thank You to lupu_sandu For This Useful Post:
    budG60 (5th September, 2015)
  10. #8
    your car is 328ci M52...?
    if so? i think your ISN - 8D 48
  11. The Following User Says Thank You to maxtorrld For This Useful Post:
    budG60 (1st September, 2015)
  12. #9
    Above sea-level
    Programmed the ISN code to the emulator and connected it to the EWS line of the ecu, but the car still does not start. Any suggestions?
  13. #10
    avital's Avatar
    Upload foto emulator, and I say You what problem.
  14. #11
    Above sea-level
    this is the emulator I have installed
  15. #12
    Jul 2011
    Are you able to flash 512kb file onto your ecu?
  16. #13
    avital's Avatar
    This type emulator work only with EWS2(and EWS3 in EWS2 mode) systems, MS42 use EWS3 system.
    Thats this emu never will work with ms42.
  17. #14
    Above sea-level
    Quote Originally Posted by Cloudforce View Post
    Yes, by usage of a flash programmer :-)
  18. #15
    Above sea-level
    where to find a working emu for ms42 or how to put in in ews2 mode?
    Quote Originally Posted by avital View Post
