Results 1 to 3 of 3
    Maxx232
    Guest
    Default Peugeot 307 lock ECU
    Car year 2003 2.0 HDI 79kW, ECU Bosch 0 281 011 081 EDC15C2, the BSI Valeo 9651196680 error is not synchronized key, electronic control of the motor is locked, error problem at unlocking code in anticipation of responses main BSI,
    how to unlock the motor ECU.
    number7hd's Avatar
    Dec 2013
    It happens sometimes in BSI that it lost KEY's by unplugging battery. You need DIAGBOX to synchronise KEY's. To synchronising KEY with BSI You will need PIN CODE. You should find it in service book or in eeprom in BSI.
    Maxx232
    Guest
    PIN cod own reported the keys and the BSI has accepted coding or error locked motor ECU Bosch 0281011081 EDC15 C2 error in transferring code unlocking pending replies from the main stored in your or BSI
