Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 69
  1. #46
    macako6's Avatar
    Mar 2015
    Quote Originally Posted by flamb View Post
    Ok .
    Attached my original map...
    Someone can help me to remove DPF regeneration and Adblue ?
    Thank's to all
    Your file DPF and SCR off
  2. The Following User Says Thank You to macako6 For This Useful Post:
    flamb (14th September, 2018)
  3. #47
    Sep 2018
    Quote Originally Posted by macako6 View Post
    Map writed ok.
    Fuse removed.
    Adblue level no error, but it pass from 3 balls to only 1 , it's normal ?
  4. #48
    macako6's Avatar
    Mar 2015
    Map writed ok.
    Fuse removed.
    it's normal
  5. #49
    Sep 2018
    it's normal
    In this map the rail pressure / turbo pressure etc. is stock ?
  6. #50
    macako6's Avatar
    Mar 2015
    Default Mazda cx7 2.2 177hp adblue
    Yes all stock . Only Dpf SCR off
  7. #51
    Dec 2018
    No EGR . Onli DPF and SCR
    Hi there i just remove the adblue from mi cx7 and the adblue light is on the dash wath can i do? Thanks
  8. #52
    Sep 2018
    Quote Originally Posted by Crisu83uk View Post
    if you have active errors on the dashboard you must first solve them. afterwards you can remove everything (dpf and AdBlue)
  9. #53
    I need help to disable ONLY SCR System in this Mazda CX7 2.2 with Denso ECU.
    If necessary I can unplug the SCR ECU under driver seat... And will the light in dashboard will be off?
    Working solution would be grat!!
    Thank you
  10. #54
    Is here anyone who wants to help me?
  11. #55
    macako6's Avatar
    Mar 2015
    Default mazda SCR
    Here's your solution SCR off
  12. #56
    Can someone else help me, macako6 did't send the password...
  13. #57
    Please, I need help. Only SCR off and no light in dashboard.
    Thank you
  14. #58
    Aug 2010
    Norway
    Hi.
    Guys ... i need help with remove adblue in my CX-7
    HW: R2AX-188K1-A
    SW: R2AX-18881-L
    SW ver.: R2AX-18881-E
    I tryed to do this with swiftec ... but on the display still is SCR malfunction ....
    And km to stop motor goes down...
    Module SCR is disconnected , and fuse is removed ....
    Now i have ori file in car ... tryed to repair ... but
    filling up tank with adblue is not possible because sonde have fault .....
    So best will be remove it ....
    Mazda CX7 ORI.rar
  15. #59
    Feb 2013
    UK Bristol
    Guys. How sort it out solution with message on cluster about adblue.
    After run engine there is 3 times beep buzzer and the same time 3 times blink adblue led on dash there gone.
    Another things refill adblue millage is going down.
    I try use forescan with elm327 and disable some function on cluster but is not many anout adblue, or disable beeping.
    Any idea
    My post helps you? Please Hit Buttons
  16. #60
    Feb 2013
    UK Bristol
    Nobody cant help?
