Page 542 of 555 FirstFirst ... 42442492532537538539540541542543544545546547552 ... LastLast
Results 8,116 to 8,130 of 8323
  1. #8116
    Romania
    Hi. Need one immofile from any mqb 5C used by vvdi2 if anyone have and willing to share.
  2. #8117
    Aug 2015
    VVDI Prog RH update is already for public download available?
  3. #8118
    Jun 2017
    US
    Anyone seen this when trying to generate a Toyota prox? Tried the hold lock and insert battery reset.
    365803784_7121556184543820_695999451340022129_n.jpg364706041_7121555221210583_845415602319175835_n.jpg
  4. #8119
    BIM Tool v1.9.0 released which supports BDC unlock via OBDII.
    Will we see this feature on VVDI2?
  5. The Following User Says Thank You to u.s For This Useful Post:
    p1et (10th August, 2023)
  6. #8120
    http://dl.xhorse.com/product/vvdi2/s...tallerV735.exe
    *** 2023-08-11
    *** Require firmware V7.3.5
    ===== VAG V7.3.5 =====
    1. Improvement autodetect for VAG immobilizer system
    2. Improvement online calculation for MQB system: Lock NEC35xx/RH850/NEC34xx+95128
    3. Bugfix
    ===== BMW V7.3.5 =====
    1. Unlock BDC module via OBDII. Easy and fast job(SWFL_00002419.085.xxx.xxx not support OBD)
    2. Bugfix
    ===== Porsche V7.3.5 =====
    1. Bugfix
    ===== PSA V7.3.5 =====
    1. Bugfix
    ===== Transponder Programmer V7.3.5 =====
    1. Improvement prepare remote funciton
    a). Support FengshenS30, SANYI, Jiefang types make remote directly
    b). Require load BCM file read by VVDI-PROG
    2. Bugfix
    ===== Copy 48 (96 bits) V7.3.5 =====
    1. Bugfix
    ===== J2534 V7.3.5 =====
    1. Bugfix
    ===== Online Upate Tool V7.3.5 =====
    1. Bugfix
    ===== Quick Start V7.3.5 =====
    1. Bugfix
  7. The Following 2 Users Say Thank You to u.s For This Useful Post:
    rob h (14th August, 2023), vialli (12th August, 2023)
  8. #8121
    vialli's Avatar
    Aug 2018
    Romania
    This is really great news!!!
    TOP TOOL
  9. #8122
    Sep 2016
    the entry point to the Initialize SRWLock procedure was not found in the DLL KERNEL32.dll
    After upgrading to version 7.3.5
    WindowsXp. Version 7.3.2 working ok.
    What to do?
  10. #8123
    rob h's Avatar
    May 2011
    Any future plans? Reading bcm hfm Renault and Nissan immo perhaps.
    R7F701056 bcm
    R7F701019 hfm
    R7F701025 hfm
    Thanks for all the great work sofar.
    I use Xhorse everyday.
    I wont mind buying some more options in the future.
  11. The Following User Says Thank You to rob h For This Useful Post:
    p1et (16th August, 2023)
  12. #8124
    Mar 2018
    Quote Originally Posted by lock66 View Post
    What to do?
    hello, have you installed the upgradekit firmware?
  13. #8125
    Aug 2018
    Hi can someone check bcm2 locked after read via vvdi and vvdi2 i have immo data but i need CS and CP for change procedure BCM2 Can somone if immodata contain this? Thanks
  14. #8126
    PierreTheron's Avatar
    Centurion,South Africa
    had problem with audi immo data with vvdi 2 on tryin g to read and edit it to program key . used autel to program the existhing key and did it with no problem at alllSo
    i think autel is still Ahead off the game
  15. #8127
    Sep 2016
    Hello.Upgrade kit not update firmware vvdi2.
  16. #8128
    Apr 2022
    Germany
    Quote Originally Posted by PierreTheron View Post
    Which Audi have you done? Model? Year?
  17. #8129
    Maartinj's Avatar
    Nov 2010
    unbelievable
    you must be in Roswell and UFO block your device
    look outside mate
  18. The Following 2 Users Say Thank You to Maartinj For This Useful Post:
    musti418 (21st August, 2023), PremierD (17th January, 2024)
  19. #8130
    Sep 2016
    The device is not blocked.
    The device works without problems, but only on version 7.3.2.
    It's only worth upgrading to version 7.3.5.
    The device is not defined.
    Windows XP sp3
