I have dash in normal state. I was trying to manually change immodata and write it (earase lost key, change key count). As I can see I can not do it. VVDI2 read immodata good. So the problem is when I would like to change to another RB8 dash and write immoblock ?? Somebody tried ??
yugo45 (7th May, 2017)
You are right, there is 95320 I didnt see it at first time, but still my eprom was corrupted, that it is the reason why vvdi coudnt enter in KP mode. Sergey from info.autokey.by fixed my eprom and manually enter in KP mode, so I could learn key. When key was learnt, I read 95320 again and he changed data for removing KP mode. The car starts![]()
amigokola (8th May, 2017)
Hello mates I made all key lost cas 4 from f10 2012 using vvdi2
The vvdi2 software didn't ask me for ecu dump
Just made key and didn't write back the dump to CAS
Key worked well for 1 week now car says key not detected sometimes work sometimes not
What could be the problem I did
Sent from my SM-G935F using Tapatalk
ibratex (9th May, 2017)
EMCE159 (11th May, 2017)
This week i had E61`10 resurrection with stolen CAS and LM modules. Had to pair used CAS3 (ISTAP version) to car with ISN from ECU using VVDI Prog and learn 2 new keys with VVDI2 to get car started (all keys lost scenario). All worked perfectly.
One thing that got me stuck for an hour was that i couldn't SYNC DDE-CAS with ignition ON. VVDI2 was showing that "DDE-CAS sync not possible", and that is not mentioned in VVDI2 BMW manual.
I have been working with VVDI2 for almost a week now and i have to say it is GREAT tool to have. Capable to do a lot...
Thanks XHORSE and user: Maartinj from whom i got it.![]()
VVDI2 latest software version V4.2.0 update:
*** 2017-05-11
*** Require firmware V4.2.0
===== Note =====
1. Update firmware v4.2.0 require the latest online update tool v4.2.0 version
2. Please download latest install software first then update firmware
===== VAG V4.2.0 =====
1. New function released: Audi A6L, A7, A8L, Touareg lost all key:
(1). Support ECU with MED17/EDC17 type OR Gearbox with 8 speed CVT type
(2). Require BCM2 data, most of them can read with VVDI2 via OBDII
(3). Require ELV data, you can read with VVDI-PROG
(4). Switch ON igniton with OBDII operation, simple and safe
(5). Collect data from internal-can
(6). Fast calculate speed, only need 1 minute
(7). Freee for all customer with immo5 authorize, every success calculate require 100 remote points
2. Bugfix for immo5 keylearn
3. Bugfix for write A4/Q5/A5 KM
4. Bugfix for read pin and CS from ECU (SIMOS PPD1.1/1.5)
5. Bugfix for flash FRF file
6. Bugfix
===== BMW V4.2.0 =====
1. Bugfix
===== Porsche V4.2.0 =====
1. Bugfix
===== PSA V4.2.0 =====
1. Bugfix
===== Transponder Programmer V4.2.0 =====
1. Support Inida Mahindra special transponder ID46: Xylo, Scorpio
2. Immobilizer data tool: add new for Suzuki swift 2012- 93C86
3. Immobilizer data tool: bugfix for Opel IMMO-2 TMS
4. Immobilizer data tool: bugfix for Brilliance Zunchi 93C64
5. Immobilizer data tool: bugfix for Fiat Marea 93C46
6. Copy Transponder support the latest copy transponder(HITAG2)
7. Bugfix
===== J2534 V4.2.0 =====
1. Bugfix
===== Online Upate Tool V4.2.0 =====
===== Quick Start V4.2.0 =====
1. Bugfix
AndyCZ (11th May, 2017), CaioW (11th May, 2017), CarCity (11th May, 2017), chli1976 (11th May, 2017), daxxer (11th May, 2017), dmp (11th May, 2017), duplikeytor (11th May, 2017), Fallen (11th May, 2017), Maartinj (11th May, 2017), rola1971 (11th May, 2017), triak88 (11th May, 2017), weza247 (11th May, 2017), yui (11th May, 2017)
I have a Porsche Boxster 2011 Spare key to program. It has a I'd 46 remote key. I can find very little info on how to go about programming this key. I have full vvdi2 with Porsche My questions are
Do I need to preprogram key (dealer key)
Will Vvdi do this by obd.
If not what modual holds the key data and what will read it with.
Sent from my iPad using Tapatalk
Add life to your days not days to your life
P
purdy (11th May, 2017)
