yes, working ok on pcr 2.1 but need to find cs and pin by other ways
Does the vvdi prog can be used to read mcu id of tc cpu
Sent from my SM-A125F using Tapatalk
Hi.
Has anyone programmed the Xhorse key as 89071-0D030 433MHz for Toyota Yaris 2010?
I have tried different programming methods but without success.
What did you try?
Where did you fail - transponder or remote? When you try the manual procedure, does it enter programming mode?
There are no different programming methods. Only a correct method
https://www.youtube.com/watch?v=6XS6bbPaJfo
Learn to ask the correct questions to get the correct answers instead of making us hint and guess...
elmaro (8th November, 2022)
My mistake. I did not add that it is about the remote control. The procedure for entering the remote control programming mode is successful. The lock closes and opens but no reaction to the remote control buttons.
It happened to me in the same vehicle recently, I made kdx2 from keydiy. 0d050 done
If you have a mini keytool, you can do it through the android program.
Is VVDI2 able to program new key for BMW G30? Or program/replace FEM/BDM to used ?
roger06 (27th November, 2022)
2022-11-30 Require firmware V7.2.7
===== VAG V7.2.7 =====
1. Improvement autodetect for VAG immobilizer system
2. Bugfix
===== BMW V7.2.7 =====
1. Bugfix
===== Porsche V7.2.7 =====
1. Bugfix
===== PSA V7.2.7 =====
1. Bugfix
===== Transponder Programmer V7.2.7 =====
1. Improvement prepare remote function
2. Immobilizer data tool: Euro->BMW->Motorcycle->Immobox(R1200,C650,K1600,K1300,C600,F800) bugfix
3. Immobilizer data tool: Euro->BMW->Motorcycle->K19 bugfix
4. Bugfix
===== Copy 48 (96 bits) V7.2.7 =====
1. Bugfix
===== J2534 V7.2.7 =====
1. Bugfix
===== Online Upate Tool V7.2.7 =====
1. Bugfix
===== Quick Start V7.2.7 =====
1. Bugfix
Latest software download from
Quick Lunch -> Update Online -> Software Update and Update information
darknezz19 (6th December, 2022), Supas (2nd December, 2022), triak88 (2nd December, 2022)
Golf 7, 2013 0580 dash, faild.
wuza (30th December, 2022)
what about in new update 7.3 and bmw motors learn key its not open for use,need to contact dealer?
sharpshooter86 (11th January, 2023)
