Today tried to make transponder from dump Toyota Aygo. Read eeprom 24C04.
When try with transponder programmer get error unsupported version
With avdi tag key tool no problem.
2013 CW CC MED17.5.2 swapHello everyone, I have a vw cc 2013 with MED17.5.2 and would like to swap it. The shop had swapped the ME but they had an ME with a wrong type. The car starts but it has a fault code for an air injection but the car has no AIR injection. Now, we have a correct ME and would like to swap it. I have read and transferee the MAC, immo pin etc to the used ME but still have immo fault and can’t start it. I can’t do anything over the OBD2, the VVDI is not getting needed data. I don’t want to clone it because then I will have two MEs with air injection fault codes. So, I did the eep adjustment with the pin, MAC, VIN etc. what am I doing wrong here? It’s my 1st time doing this type of work in this MEs. Thank you in advance
if vvdi2 cant do that job, why you post info here ? maybe flash your current ecu to proper software ?
Hi! VVdi2 7.3.5 dont read Texas AES keys Toyota. It for all?
ID48 chip cloning today .....2 min.....yes, min (no hours) 120sec.....what happened?
I don't know where you're from... but I recommend you go play the lottery! It's your lucky day... jajaja
Now speaking of truth... Although there are times with more server usage than others and it takes more or less... I hope they have resolved something and it will be like this from now on... a faster service.
Did you clone an original locked id48 96 bit chip?
Are we talking about vvdi2 with the data collector accessory? Or with xhorse's minivvdi do they get the same time?
Supas (10th November, 2023)
Hello can someone tell me which Xhorse universal remote use for VW MQB cars non proxymity. Thanks
My VVDI2 is damage. If I purchase a basic version of VVDI2, will I be able to transfer the old authorizations to the new VVDI2?
