Results 1 to 14 of 14
    May 2013
    Default Audi Q7 Replace ECU / ECU Cloning (WATER DAMAGED)
    Hi Guys.
    Audi Q7
    3.0 6 Cyl
    Diesel
    Automatic
    BOSCH EDC16 ECU
    Short story is....
    ECU Water Damaged. Bought another ECU from Smashed Vehicle. Car will not start. Instruments show SAFE and ECU DTC Scan it shows CRASH SHUTDOWN ACTIVATED.
    Tried to move eeprom 95320 from old ECU to new (Donor) ECU but car would not crank. DTC show "ECU not Coded or incorrectly coded".
    So can somebody clone the original eeprom to the new one. Obviously we need to keep old VIN but odn't want the new eeprom because it has a permanent DTC of CRASH SHUTDOWN ACTIVE.
    Here are the files from old ecu and new donor......
    Thanks guys
    eliasole's Avatar
    bad read of donor ecu , try to read again
    mihaiservice's Avatar
    http://www.quick-tuning.com
    for the correct job you have to write flash+mpc+eep contempt from original to donor ecu ! also check if both ecu are with the same label
    Mike
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Readout from new ECU is bad
    May 2013
    Quote Originally Posted by eliasole View Post
    Hi there
    Updated the post with dump read by xprog. First dump was read by VVDI via OBD.
    eliasole's Avatar
    VIN: WAUZZZ4L47*035*81
    CS:40CA6754819400
    MAC:C0DF1E08
    PIN:37703
    Good luck!
    May 2013
    So do I just write this eeprom with xprog and it should work?
    No coding or adaptations needed?
    eliasole's Avatar
    YEAP!!.............
  9. The Following User Says Thank You to eliasole For This Useful Post:
    onejay10 (1st October, 2019)
  10. #9
    Feb 2018
    manchester
    How did you repair this eeprom @eliasole ?
  11. #10
    Feb 2018
    manchester
    YEAP!!.............
    Can you tell me how you repaired eeprom?
  12. #11
    May 2017
    post your damaged one
  13. #12
    Feb 2018
    manchester
    Quote Originally Posted by Lambda1 View Post
    I will have access to the car in a few hours my friend, thankyou, I will post again when I have the dump.
  14. #13
    Nov 2018
    P L
    post here dump oryginal and donor. if oryginal dump not damaged, sometime enough rewrite oryginal file and ECU coding, sometime enough only rewrite, and work
  15. #14
    Oct 2018
    Hi change org old ecu eeprom to new donor ecu epprom chk ok test and report
    2 file immo off
    login 40915
