Results 1 to 15 of 17
    gsmik's Avatar
    Oct 2011
    Eastern Europe
    Default PASSAT B7 USA REAR LIGHT CODING
    I heve PASSAT B7 USA ( NMS) and I have to change the rear lights of the US to Europe.
    I changed buye 18 of A0 on 30. Rear lights work fine but I have a fault LED on the board.
    In BCM fault codes: light brake left and light brake left.
    If anyone knows the correct encoding for europe??
    mecale's Avatar
    Jun 2009
    ISTANBUL/TURKEY
    gsmik's Avatar
    Oct 2011
    Eastern Europe
    There is no information.
    EU
    I have same problem, someone knows how correct encoding for europe?
    dunnnia's Avatar
    LT
    Hi,what lights do you have in front?Xenon?Hallogen?Post full BCM coding with vcds readout.
    EU
    front light is hallogen.
  7. The Following User Says Thank You to subas For This Useful Post:
    There could be difference in wiring, I will try to find diagram in ELSA
    dunnnia's Avatar
    LT
    hi,try put in 18byte :64
    or try :76
  10. #9
    Russia, Kurgan
    How did you do this coding ?
    As I understand, to do this kind operations on new B7 you need special access code or do it online.
    Please, help me to understand this moment.
    UPA1.3+R270+X-ProgBox5.48+DigiProg4.85+KESSv2+Galletto3v53+Galet to1260+VAS5054+VagTacho5.0+VagCAN5.5+VagEcuTool+Op COM+KPW2000+MPPS13.02+CMD1251+RenoClip+M-VCI+CN900/4D/46+(X-100+) and o on...
  11. #10
    Mar 2017
    Hello, can you give me the codes please for converting the VW Passat B7 USA light to european. Thank you in advance!
  12. #11
    Jul 2013
    yorkshire
    I think we will be seeing lots of these with same problems due to VW buy back scheme in US. Lots of used VW cars coming to Europe and Asia.
  13. #12
    gsmik's Avatar
    Oct 2011
    Eastern Europe
    Change byte 18 to "30" and connect additional cables to BCM http://docs.google.com/spreadsheets/...Z7Y/edit#gid=0
    Attachment 436130
    The connectors as pictured left to right are T52c, T52b, and T52a.
  14. The Following 2 Users Say Thank You to gsmik For This Useful Post:
    dziongas (8th November, 2017), Tautvydas (3rd January, 2018)
  15. #13
    Mar 2017
    Thank you very much ''gsmik'' for the info. I want to ask you, did you solved the problem with converting, because I made some changes but the DRL is not working. After you made the changes everything works fine? Thanks in advance for your reply!
  16. #14
    gsmik's Avatar
    Oct 2011
    Eastern Europe
    If you change byte 18 by 30 rear lights and headlights work ok but DRL not work
  17. #15
    Jan 2018
    Hello guys, so in VCDS, byte 18 should be changed to "30", after that we need to swap some wires in BCM for rear turn signals, and also install additional wire from BCM to trunk for rear fog light. Am I right?
    Also, byte "30" change BCM pinout to which car? Passat CC?
