Results 1 to 12 of 12
    Oct 2011
    Default opel astra g ecu bosch 0 261 206 232 16valve 2.0l immo off needed please
    hi there
    got a few miff cars in workshop at the moment, this one came in without the immo pick up ring, can anyone see if they could do a immo off on this ecu please, attached is the 24c02 read on orange5, the info on ecu is bosch 0 261 206 232 gm 93 600 373 and 20sel made in south Africa, thanks for any assistance ,except matches all the best
    astra g 24c02.rar
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Hi.Check this one:
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  3. The Following User Says Thank You to drewdom For This Useful Post:
    raptureready (18th August, 2015)
    Oct 2011
    Hi there, tried the dump , the engine management light flashes and fan starts to run when ignition is turned on , engine swings but no start
    drewdom's Avatar
    Aug 2010
    Im sorry mate this was my one shot.
  6. The Following User Says Thank You to drewdom For This Useful Post:
    daniersms's Avatar
    South Africa
    Hi this file drewdom gave you is good for your ecu ---- always worked for me
    Love this forum
  8. The Following User Says Thank You to daniersms For This Useful Post:
    raptureready (19th August, 2015)
  9. #6
    Oct 2011
    thanks, can you tell me if there is a pin code in the ecu and if there is ,can you let me know, from my original dump , what about getting another immo pickup ring and coding to car, can this be done, i have opcom and avdi, just another thing , the dump from drewdom must i do anything else or just load dump? thanks again for assistance , all the best
  10. #7
    daniersms's Avatar
    South Africa
    Just write the file into the eeprom and disconnect the transceiver and it should be ok
    Love this forum
  11. #8
    May 2012
    hello There is no immo off for this ecu in myu opinion. All you have to do it;s to take a immobiliser with transponder and to reprogram with ecu but you need pin for ecu and for immobiliser
  12. #9
    Oct 2011
    Thanks , can I read anything on ecu to get pin? Or must I try dealer for pin, also does anyone know what this Immo transceiver part number should be , got a few from various opels , thanks again for advice, God bless
  13. #10
    Nov 2017
    Default immo off
    Quote Originally Posted by drewdom View Post
    Hi.Check this one:
    hi can you please fw the file to me 2 i have exact problem
  14. #11
    Aug 2019
    Bulgaria
    Try it. Disconnect immo box astra g 24c02 off.rar
  15. #12
    Sep 2016
    south africa
    I am yet to find a immo off for this ecu. Read pin in immobiser. I also have a saved dump you can try. I have the pin. You can write it and use it for pin.
    Sent from my SM-A515F using Tapatalk
