Hi i have a 2005 astra h 1.6 Z16XEP WONT Start
ECM fault codes-
U2103-C 1.CAN-Bus Reset Counter Overrun2.No Communication with CAN-Bus Present
ECM fault codes-
Can Hi Lo voltage test
Each node contains a CAN transceiver that outputs differential signals. When the network
communication is idle the CAN_H and CAN_L voltages are approximately 2.5 volts. Faulty
transceivers can cause the idle voltages to vary and disrupt network communication.
To test for faulty transceivers
1. Turn on all supplies.
2. Stop all network communication.
3. Measure the DC voltage between CAN_H and GND
4. Measure the DC voltage between CAN_L and GND
Normally the voltage should be between 2.0 V and 4.0 V.
If it is lower than 2.0 V or higher than 4.0 V, it is possible that one or more nodes have faulty
transceivers.
For a voltage lower than 2.0 V check CAN_H and CAN_L conductors for
continuity.
For a voltage higher than 4.0 V, check for excessive voltage.
where is the can bus located on these vehicles
Follow this link:
http://www.digital-kaos.co.uk/forums...486989-Tis2000
Download tis2000 and you can find all shemes for your car in this program.
what about fault codes in other systems? ABS , Airbag , body , etc?
P1113 Port Deactivation Position Sensor Circuit Or Swirl Flap Sensor Circuit
P1482 Fan Control 2 Circuit High/Low Voltage Or Powerstage High Temperature
P1483 Fan Control 3 Circuit High\Low Voltage Or Powerstage High Temperature
2.No Communication With CAN-Bus
U3000 Control Module
C0800 System Voltage High/Low Voltage
U2139 Invalid Signal From CIM (Steering Column Module) Intermittent
U2105 Generator Malfunction Or CAN-Bus CIM Message Range/Performance
U2100-C CAN-Bus Communication Malfunction
B0670 Airbag Telltale Circuit Malfunction Not Present
B1375-C Switched System Voltage (Ignition ON) Not Plausible With CAN Signal Or Circuit Malfunction
B0081 SPPD Sensor Not Connected (Simple Passenger Presence Detection Present
B0670 Airbag Telltale Circuit Malfunction Present
