Results 1 to 15 of 26
    here there
    Default Need help programming new key Mini Cooper
    Need help in programming new key in Mini cooper 2003 EWS module. Can anyone help me. How is this done? Do i need to read motorola in EWS? Read ISN and program new key with diagnostic equipment? I onli have launch diagun and idiag i hope the do the procedure
    p1et's Avatar
    Oct 2013
    You need to read Motorola and then program key by dump using any transponder programmer which has module for it.
    does t300 / sbb program the remote for these normally, I had one that sbb did not connect and t300 says its connected reads wrong key data and wont delete / add keys, didn't have anything else with me at the time.
    autochei's Avatar
    Mar 2013
    romania
    no need desolder. u need x prog read ews-ul with 4 wire read dump and then make chip with effi-zedbull or what u have
    but problem it s with what tool program remote
  5. The Following User Says Thank You to autochei For This Useful Post:
    catala20032004 (10th September, 2015)
    here there
    augtochei thanks do you know the pinout for reading ews with xprog?
    Jul 2013
    Scotland. UK
    Xprog has an adapter. Simply plug it into the EWS module and read EWS data from the pins. No soldering/IC reading neccesary.
    its the top row of small pins 1, 3&4.
    Use the dump and write a blank PCF7935 to the EWS.
    Best tool for these for me is EWS Editor 3.2.0 - 2 minute job.
    AK90 is also decent, especially for some Landrover which have plug like EWS2 and cant be read by the ews3 adapter.
    T300 can program remotes no problem if you have barcode tag that comes with key.
    autochei's Avatar
    Mar 2013
    romania
    i agree with instakeys i make many car with ews 3 with x prog
    Quote Originally Posted by instakeys View Post
    do you know if t300 deletes the remotes ok, as it said 4 remotes programmed, and wouldn't erase.. it said success a few times but it didn't erase. will have to go back soon as it was just for a friend so only took minimum tools with me.
  10. #9
    Jul 2013
    Scotland. UK
    Quote Originally Posted by paul_12345 View Post
    I cant remember if the T300 had erase remotes as a function? Does it no only give you 'PROGRAM REMOTES' as an option?
    Been a while since i did one mate, but if i remember right, have these Mini's not got x amount of spaces (10 possibly, same as EWS?) then once the maximum number of remotes are added that's it - New module time? I thought that's how they worked.
    I have no idea to be honest... I just get the b**tard running - then hit the road.
    I'd like to add, 3Dgroup remotes are brill for these though. Never had any problems, and only 40 bucks.
  11. #10
    Jul 2013
    Scotland. UK
    May 2015
    I use EWS Editor to read EWS dump, generate key and use AK90 to program transponder because writing transponder with EWS Editor is not so good.
  13. #12
    west mids, uk
    I fine mini remote programming hit and miss, Ive used ori AD and t300 etc but I rarely succeed in getting the remote to work
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  14. #13
    autochei's Avatar
    Mar 2013
    romania
    Quote Originally Posted by phuongnt View Post
    no need to program from dump it s ready to start
  15. #14
    Jul 2013
    Scotland. UK
    Yeah, I agree. It is complicated to do the job fully with EWS Editor if not sure how to write PCF
    Fastest way, read dump from EWS with that, then use Effi and zedbull. write existing key slot 0 to PCF - no need to write back anything to EWS, car starts.
  16. #15
    Jul 2013
    Scotland. UK
    Whats INPA like for Mini Remotes?
    Never used the poor mans BMW software maself like, but it does sync EWS and DME and what not... and other bits n bobs?
    Mite buy it and see. Anyone know if it does?
    Also, enabling and disabling EWS keys by OBD? Can it do that?
