Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    dariobmw's Avatar
    near THE NORTH FACE
    Default Toyota MMT BIG problem
    Good morning i need help from a good toyota expert , i bought a toyota corolla with MMT transmission
    and the clutch fried , after some time the car was on my garage a friend told , sell to me that .......
    and now the problem started !
    i detached the battery and changed the clutch , start the car ( from here all ok ) and a not good clutch
    release was the first symptom (the car before run good but the clutch slip from all gears but no errors
    on dash ) .
    So the intention was to make a adaption to the clutch actuator (like the smart) and with the diagnostic
    connected ,after the adaption the N on the dash disappeared OMG !!!!!!!!!! no more clutch no more
    gear actuator no more rpm over the idle , the strange is on the dash NO LIGHT ON but no N too .
    Now the car is a good ornament , and annoying to move .
    1st question WHY THE N DISAPPEARED ?
    2nd how can i make the car run again ?
    Please no answer to take some petrol and burn because i a big temptation !
    Ireland
    These are a pain. What equipment are you using? The N disappeared because it lost the gearshift adaptions when you tried to learn the clutch. You now need to program the clutch and the gear shift actuator. Sounds easy but it isn't simple to get them to program.
    dariobmw's Avatar
    near THE NORTH FACE
    Thanks for reply , i try some times to re learn but no more clutch or gear shift actuator move .
    The equipment for the 1st try was a texa axone 4 and then i tryed with a X431 and manually with the
    13 - 4 pin procedure but no luck !
    Now im lost with this stupid problem (take a look the car has no one error in all modules)
    Probably i wrong something but with the manual procedure no buzzer sound from car after the 7 foot
    brake depress ................. i think im too dumb for make this car run again !
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    First of all i suggest you to pull out your head from your ass... Cool down, it's a joke of course...
    I don't think there is a problem with the adaptation procedure, may be is a problem with mechanics (bad clutch, bad mounting...)
    Look again at the assembling. Inspect the connectors etc.
    Cheers!
    dariobmw's Avatar
    near THE NORTH FACE
    Thanks for reply , (my head is there for concentration is the quite place i know ) after finish the reassembling the car was on the street for about
    5 / 6 km and good running but on start the clutch was like a 80 years man driving , so i make the adaption and now is the problem !
    i think i look for any kind of error or damage but the car was fine before the adaption
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    first time i see this so no comment but this is my 2cent to add
    http://www.blue-print.com/mmt/INF134...65_266_274.pdf
  7. The Following 5 Users Say Thank You to jakesman For This Useful Post:
    bobolin4o (22nd September, 2015), dariobmw (22nd September, 2015), furnata (20th March, 2018), kronk92 (6th January, 2017), MJRVR (22nd September, 2015)
    Jul 2016
    i just changed my clutch on my toyota yaris diesel MMT
    i know it s been quite a long time and i hope you managed to fix your problem
    Anyway... it was a real nightmare, and i had the N disapeared of the dashboard too .
    i ve first thought it was the actuator problem... so i dismantled it to clean it and add some grease ...
    but the problem was still there... so after lots a research ... i have tried lots of combination (i did it with a wire... not the computer tool)...
    even now i still dont know the exact procedure ...but i can assure you that your actuator and the MMT ECU are fine
    it is normal that the initialisation of mmt ecu make the N disappear.
    First... i have extended the rod on the actuator (just dismantle the motor and use a screwdriver )
    then i loosed the 3 screw that fix the actuator on the gearbox.
    after that i have used the method that is meant for the toyota corolla... (which have one more step ... initialisation of transmission)
    then the N reappeared... but then the N was a flashing N
    and no gear was available.
    that s where i don't really know what i did... i think that i just switch off the car (when you switch off the car it seems that the actuator is set to adjust it self ...) and then tighten the 3 screw ,(or maybe i did another initialisation procedure ?) well i cant remember very clearly as i did it so many times with so much variations ... just try everything and do not loose hope
    Hope this message will help other people that are trying to fix their mmt clutch as there isnt lots of info on this
  9. The Following User Says Thank You to nono94 For This Useful Post:
    ascotauto (30th August, 2018)
  10. #8
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default mmt toyota yaris
    toyota yaris mmt
    toyota 89530-52160
    aisin 324811-11660
    and toyota 98530-52162 aisin 324811-11662
    learned dump works for 2 ecus
    ecu behind dash....
    free for all
  11. The Following 22 Users Say Thank You to vasko For This Useful Post:
    Aajii (22nd May, 2019), ascotauto (30th August, 2018), dziongas (13th September, 2016), erron (4th January, 2018), generalelect1 (11th January, 2019), gmardonesn (21st May, 2019), hguritr (22nd June, 2018), HONDA C (12th March, 2019), jodies auto (24th February, 2019), kismurmi (10th April, 2024), marcobh5 (11th March, 2022), Mezz_cro (24th January, 2024), MOBILTRONIC (25th June, 2023), mr G (6th December, 2019), neilpryde60 (2nd May, 2022), Nevidimia (17th January, 2019), niku001 (21st June, 2023), pvkosherov (19th August, 2024), RUSLAUTOEL (25th January, 2023), SAMMAD67 (11th March, 2018), Stelaras (9th June, 2017), tamer1024 (16th January, 2019)
  12. #9
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    when eeprom in gearbox corrupted car run at idle...remove plugs start car and run perfect...
    tested many times
  13. #10
    I have the same problem tried the toyota corolla method and still cant get the n to reappear if anybodys got any ideas im all ears thanks
  14. The Following User Says Thank You to dave44694 For This Useful Post:
  15. #11
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default corolla mmt
    for toyota corolla
    89530-12220
    100% work
    write dump and learn with launch or kts
  16. The Following 10 Users Say Thank You to vasko For This Useful Post:
    ascotauto (30th August, 2018), cristiannitu (12th March, 2019), kamonyi (12th December, 2019), klonone (17th April, 2020), marcobh5 (11th March, 2022), mr G (6th December, 2019), niku001 (21st June, 2023), theundetaka (14th June, 2023), tony59 (14th February, 2023), Viliuxxx (24th January, 2024)
  17. #12
    Jan 2017
    Hi Dariobmw,
    I am having the same problem after changing clutch. No indicator on dash and only idle, no throttle response. Something went wrong during initialization.
    Did you ever get your clutch fixed? If yes then how?
    I looked at the nono94 method, but the corolla has a different actuator then the corolla (with two servo motors).
  18. #13
    Jan 2017
    Quote Originally Posted by vasko View Post
    for toyota corolla
    89530-12220
    100% work
    Hi Vasko, Thanks for posting the dump, but how do I get it onto the MMT-ECU?
    I have a cheap chinese OBD-USB (cloon) cable. Can I acces the MMT with this cable and my laptop? What else would I need?
  19. #14
    Jan 2017
    Default eeprom succes, but initializaion failure
    Quote Originally Posted by shailinb View Post
    Hi Vasko,
    I Found someone who loaded the de EEprom onto the MMT-ECU. The "N" Reappeared. Great! Thanks for the eeprom, you are a genius.
    Now I started initialization using the Bleu-print manual. The manual has 5 steps:
    1) Clamp position
    2) initialize MMT
    3) initialize clutch
    4) System learning
    5) position calibrating
    I started with step 2) but already in this step the "N" disappeared again.
    So again EEprom loaded and "N" reappeared. Trying the put shift in gear (without initializing again) makes the "N" flash with red wheel light appearing.
    When I turn the car off and after 30 second on again the red light turns off and "N" is not flashing, but still will not go into gear. It will flash again. b.t.w. gas is in this fase responding.
    All plugs etc. are ok. Also the U0100 - OBD code got solved when flashing eeprom.
    Now what to do?
    Could it be that I have to skip some steps of the initialization process. Perhaps loading eeprom is same as step 2) and shall I then start at step 3)? Nothing is happening when trying step 4).
    Hope you can help with follow-up step. Thanks.
  20. #15
    Jan 2017
    have same problem here. dump doesnot help. any ideas?
