Results 1 to 2 of 2
    EUROPE
    Default toyota auris 1.4 d4d dpf problem
    Hi guys i have this toyota with ecu number 0281016911 edc17cp07.I have p2463 and sometimes p0400 the car can not accelerate and in the dashscreen is the engine light esp light and vcs light on.I tried to erase them but the 2463 is still there and the car has no power.I read the ecu with galletto v54 with 1 minute!!!Is it ok?The galletto can write it or i will have problem?Also with the autocom i can not set into ecu new dpf.Here are the two files eeprom and chip can somebody help me with this car?I read here from a member that this ecu has only a switch for the dpf off.Also i have a file from a friend but said to me that is made by volta.
    EUROPE
    anybody?A member said to me that swiftech solution is ok for this ecu can someone help?
