Results 1 to 13 of 13
    p1et's Avatar
    Oct 2013
    Default Audi A3 8P 2012 immo lockout
    I was trying to make spare key with MVP Pro. I tried to get pin and precoding from ecu and from cluster but no success. At last, I entered 'auto immobilizer detect' to see if it find pin automatically. After web security challange it gave command 'all unavailable keys will be erased, do you want to continue'. I didnt want to continue as didnt have pin/precoding so didnt know the procedure will succed so went back. Wanted to say 'I cannot do that spare key' to customer. But now the car doesnt start on original key and in immobilizer status there is 'immo lockout' It was 250 min, now is 130. Is there a chance that after that time, the car will start? On original key, the dash does not display any SAFE or immo active. On new key, without transponder, there is SAFE.
    autochei's Avatar
    Mar 2013
    romania
    I THINK AFTER 250 MIN finish u can start the car with customer key
    problem it s way mvp blocked the car? very dangerous tool mvp
  3. The Following User Says Thank You to autochei For This Useful Post:
    p1et (2nd October, 2015)
    vlado kljucar's Avatar
    Sep 2013
    Montenegro
    after lockout if you did not enter to erase key car will start on working key..
  5. The Following User Says Thank You to vlado kljucar For This Useful Post:
  6. #4
    p1et's Avatar
    Oct 2013
    Yes you were right. After lockout, the car started on original.
    p1et's Avatar
    Oct 2013
    MVP is so 'unfriendly' for such car... Engine code was not on the list so tried to read pin from couple of listed ecu types - no success. Then tried from Cluster TP 2.0 - no success. Then some other listed and still no success. I don't really know what 'automatic immobiliser detec' function does but I just wanted to check if it will try to find pin code. After AD web challange, it went to screen where I had: erase keys, program keys, immobilizer status and key status. No mention of pin code reading... When entered 'program keys' it displayed all unavailable keys will be delated but I dont know what next screen would say (if I would press enter). Maybe it will start searching for pin/precoding then... Soo much chaos on this menu. I will ask on AD forum and try again if they tell it's worth. I have vin and engine code.
  8. #6
    Quote Originally Posted by p1et View Post
    A3 after 2009 isnt to do easy without eeprom read from cluster.
  9. #7
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Go ad forum and see how many it muck up
    and also change cs data
    use at own risk
    mess with these cars and not proper tools
    you will get badly burned
  10. The Following User Says Thank You to whiskeyman For This Useful Post:
    obdsystems (5th October, 2015)
  11. #8
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by whiskeyman View Post
    Can't see any single one about 09+ hah . So maybe it's true and admins delated
  12. #9
    Aug 2015
    Abrites will do these EDC17, MVP no chance.
  13. #10
    Sep 2015
    Washington, DC
    12 A3 is not supported by AD
  14. The Following User Says Thank You to Kinskeys For This Useful Post:
    p1et (4th October, 2015)
  15. #11
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Actually AVDI doesn't do 2009+ as it MUST read the ECU cos dash is locked out.
    In fact, I've struggled on some eariler with AVDI - if car has been "chipped", which is not uncommon on these, the ecu flash comes back with random CS & pin-code data.
    So to sum up, about 07+ dashes are lock'ed out. You need to do via eeprom 09-12
    I am a FUD
  16. #12
    Fallen's Avatar
    Quote Originally Posted by obdsystems View Post
    Actually AVDI doesn't do 2009+ as it MUST read the ECU cos dash is locked out. In fact, I've struggled on some eariler with AVDI - if car has been "chipped", which is not uncommon on these, the ecu flash comes back with random CS & pin-code data. So to sum up, about 07+ dashes are lock'ed out. You need to do via eeprom 09-12
    Are you trying to use instrument CAN to add keys to these?
  17. #13
    Aug 2015
    Though an048 for abrites could do these ?
