Results 1 to 3 of 3
    pinheiro's Avatar
    Portugal
    Default Citroen Berlingo III P1352
    Hi friends
    I have a Citroen Berlingo, 2010, 1.6 HDI, 90 Cv.
    The engine light turned on, and by diagnostic it appears the following dtc code fault:
    P1352 - engine pre heating
    I've allready changed the glow plug realy, but next day it happens the same. The light turns on and the same fault code.
    What could it be? Anyone had a similar problem.
    Pinheiro
    Jul 2013
    yorkshire
    Did you test the relay, or just guess? Check the glow plugs. They are easy.
  3. The Following User Says Thank You to autoden For This Useful Post:
    pinheiro (25th October, 2015)
    Yes glow plugs check resistance on the four,you will find problem, if you disconnect coolant temp switch will go into default,you can then check glow plugs are getting power.
  5. The Following User Says Thank You to radiosolutions For This Useful Post:
