Meriva B pin code read from A17DTR ecu - No
autotechmx (24th March, 2019)
what means "use backup supply" when using FDVI ?
additional car battery in parallel ? Why is there such a drastic voltage drop when using FVDI ?
Hi all
Captiva 2.2 2012year ECU DCM3.7, you need to make an ECU virgin. Chinese FVDI will do?
no. you can`t do by fvdi.
i have fvdi with 18 softwares but i need jag and land rover where can i get this
if you have pin code you can virginise that ecu by opcom ori or mdi
There is no PIN in this block
Key learning Fiat Doblo 2004
Fvdi 2014 v5.4
Read Bcm marelli 9s12DG256-1K79X- ok
Read pin - ok
Transponder maker prepare id 48
Learning Spare Key - ok
Key learning successfully![]()
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
kronk92 (2nd November, 2017)
Hy. Can somebody help me what is the problem with interface. Few days ago i bought FVDI2 Opel 6.6 version and the first day works and the second days its not work. The program says no hardware syncronization 0 days left. And i cant read sec code from dis cant make everything this. 20170504_170259.jpg
- hello
- is it possible to use a softwar fvdi v2015for a device fvdi v2014...tnx tnx tnx
Hello Smart Heads!
I've got FVDI with some troubles. Got accidentally overvoltage on board.
AU5790D had big hole with burning stench and uc got short circuits (all capacitors).
So I replaced them.
Now I have no communication (Via USB). PC do not see FVDI in any case.
Uc is unprogrammed already but I do not know it can help.
I do not see any futher damage on board.
Please for help.
If You need more information, please tell me.v
Latest "news" from Fly ...
[26/05/2017 2017-5-26 V4.0 released:
1. Volkswagen/Audi/Skoda/Seat,KeyMaker(Write Key,Explorer Key,Immo Info),Support car list:
1.1 Passat B6 95320 ID46;
1.2 Passat B6 95320 ID48;
1.3 Audi A4/A5/Q5,BCM2;
1.4 Audi A6/A7/A8/Touareg,BCM2;
2. New Porsche,KeyMaker(Write Key,Explorer Key,Immo Info),Support car list:
1.1 Kessy;
1.2 911;
1.3 Boxter;
1.4 Cayman;
1.5 Cayenne;
1.6 Macan;
3. BMW,KeyMaker(Write Key,Explorer Key,Immo Info),Support car list:
1.1 CAS4 Series 1 F20;
1.2 CAS4 Series 5 F10/F11;
1.3 CAS4 Series GT F07;
1.4 CAS4 Series 6 F12/F13;
1.5 CAS4 Series 7 F0x;
1.6 CAS4 Series X1(X1);
1.7 CAS4 Series X3 F25;
1.8 CAS4 XEP100 MCU(XEP100);
1.9 CAS4+ Fxx(Fxx);
FLY OBD Terminator Update Online
where I can find FLY dongle drivers.
Thanlk you.
BMW X6,
cas3+ with 0M23S hc12 program key by obd2 = ok
program new EGS = ok but with intenet connection
