Page 36 of 183 FirstFirst ... 2631323334353637383940414686136 ... LastLast
Results 526 to 540 of 2742
  1. #526
    soxten's Avatar
    Mar 2013
    Where can I find the update program?
    I have fvdi pcb v4 vag,renault,psa,hyundai,kia in 3 diffrent units.
    Is it possible to update one to all this program?
    Is it possible to read from one as have full and program to a lover grade unit?
    I see that mcu is NXP LPC1788FBD208.
    But Eeprom is not possible to read.
    Christian Johansson via Iphone 5s
  2. #527
    zhumerchant's Avatar
    Quote Originally Posted by micromax View Post
    PSA bsi read pin and mileage not work. read mileage ok, after put write button programm does nothing.
    please contact with tech support,send log file.
    no skype m8
  3. #528
    micromax's Avatar
    South Poland
    where is log file ?
  4. #529
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    I finally took the jump and thought id buy one I received mine yesterday upon opening the package and looking through it there was NO key tag tool so I contacted them and was originally told no need for it "superdog" needed only. Anyhow so I thought fair do's installed all the software and then started getting loads of errors on the fwdownloader . I managed to find the dll files it was asking for and got that to work eventually then I couldn't connect to the server believe my I tried everything anyhow I eventually got one of their engineers to help me we discovered it was due to virgin media child safe it wouldn't connect so I disarmed that and connected to the server and managed to upgrade firmwares. As for the license I cant download that and Still I cant use the device as yet as I get "device not open" in commanders and also some crash when loading.
    overall very disappointed no tag key tool and basically told its impossible for it not to be in the package not straight forward to install as a lot of driver conflicts etc and still no working device as yet!
  5. #530
    hello tesday update fvdi v2015 renault in quick loader v6.3 but renault work in v5.2 but v6.3 interface not calibrated
    i firmware in fvdi is 2.5 and update licence
    why not work in v6.3
  6. #531
    micromax's Avatar
    South Poland
    contact with support, you need table.dat for your serial and update by fwdownloader
  7. #532
    lpf01's Avatar
    Oct 2013
    I have the "old" v21 VAG, and today i had an Audi A4 with BCM2.
    Read BCM2 ok, but when i try to make dealer key it says it is failed because the key is not correctly inserted into the programmer.
    I tried it without case, in every angle inside / outside / through the transponder ring but with same message.
    Anybody had this issue yet?
  8. #533
    micromax's Avatar
    South Poland
    another transponder can read ?
  9. #534
    lpf01's Avatar
    Oct 2013
    Yes it reads ID48 for example.
  10. #535
    micromax's Avatar
    South Poland
    try orginal key, maybe this is broken
  11. #536
    Mar 2008
    manged to download license on mine worked once opened merc commander worked once and now I am getting "device not open" on all commanders this is annoying
  12. #537
    micromax's Avatar
    South Poland
    fvdi 6.3 - med17.1 boot mode not work on version vag v24, 18 work ok.
    please i need downgrade to v21
  13. #538
    super jumbe's Avatar
    Livingstone
    Overall fvdi is crap machine!!!
  14. #539
    micromax's Avatar
    South Poland
    JIMMYQ uninstall all ftdi drivers (CDMUninstaller) hand install 1 certified by microsoft, never install drivers from fvdi installer
    i work on this drivers. all ok.
    super jumbe no, its good tool, this christmas update its joke. before all module work ok.
  15. The Following 2 Users Say Thank You to micromax For This Useful Post:
    eagleone-two (7th September, 2021), vari (1st July, 2018)
  16. #540
    hello i update v2015 fVDI firmware 1and2 in v2.5 and update license and quick loader v6.3 renault v5.2 work but renault v6.3 error interface not calibrated my id is f07475 help me please
