Page 443 of 451 FirstFirst ... 343393433438439440441442443444445446447448 ... LastLast
Results 6,631 to 6,645 of 6756
  1. #6631
    Jul 2019
    Can anyone tell me did they successfully renew Mercedes edc17cp46 with VVDI Mb tool.
    This is the first ECU that gives me problem to connect.
    I can read ECU with bench /factory mode with out problem but can not connect with VVDI MB . AVDI Will connect OBD.
    I tried IM608 and same thing .
    This is pin out I use:
    12v = 5 and 15
    Ground = 2
    Can high = 41
    Can Low = 54
    and Put 120omh resistor between Can H and Can L.
    OBD as usual:
    12v = 16
    Gorund = 4,5
    Can high = 6
    Can Low = 14
  2. #6632
    Jun 2009
    i need password calculation W212, data attached recolted by VVDI Mb tool
    thanks in advance
  3. #6633
    Mar 2018
    Quote Originally Posted by immoneard View Post
    12v = 5 and 13
    Ground = 2
    Can high = 41
    Can Low = 54
    OBD as usual:
    12v = 16
    Gorund = 4,5
    Can high = 6
    Can Low = 14
    Try
    12V - 1 , 15
    Gnd - 6
  4. The Following User Says Thank You to babeh For This Useful Post:
    immoneard (19th April, 2022)
  5. #6634
    Jul 2019
    I type wrong i Was using Pin 15 for 12V.
    2,4,6 are grounds and it does not matter which pin you use.
    1.3.5 are 12V and same thing.
    I am asking did anyone was able to do this ECU with VVDI MB?
  6. #6635
    Mar 2018
    I saw an old post 3yrs ago said renewed edc17cp46 with vvdimb.
  7. The Following User Says Thank You to babeh For This Useful Post:
    yugo45 (20th April, 2022)
  8. #6636
    khalilo_de's Avatar
    Can some here pleaze help with erase pass calculation
    Here is Special key : 071989139F10D76F
    Thank you
    Envoyé de mon SM-G980F en utilisant Tapatalk
  9. #6637
    Jun 2009
    no one can calculate password for me ??
  10. #6638
    Jun 2009
    Quote Originally Posted by medcapot View Post
    thanks in advance
    no on can calculate password for me ??
  11. #6639
    Mar 2018
    Can't use your file.
    Have you try upload for calculation ?
  12. #6640
    Member autosocket's Avatar
    Sep 2010
    Hi, Has anyone here used the xhorse key tool plus for ISM renew on a w212.
    It says obd. Ive tried to read then times out after 5%
    Should i buy the adaptor set for the bench
    Resistance is futile
  13. #6641
    Dec 2019
    i made the adapters myself and always use the direct connection method
  14. The Following User Says Thank You to cl55 For This Useful Post:
    immoneard (26th April, 2022)
  15. #6642
    Mar 2018
    Quote Originally Posted by autosocket View Post
    That is OBD, but not in car ODB.
    In car will never success.
  16. The Following User Says Thank You to babeh For This Useful Post:
  17. #6643
    Sep 2010
    Thank you for the help, appreciated, ill order the cables.
  18. #6644
    Mar 2018
    There is just 4 wires, I don't think need to order cable if you know the pinout.
    Just + - CAN-H CAN-L
    and not resistor is needed.
    The layout is like that
    | - + X CAN-H CAN-L )
    (X) - no connection
  19. #6645
    Mar 2018
    Quote Originally Posted by khalilo_de View Post
    Thank you
    It is easy to get erase pass
    2D1BDFD42CFDF73C
    Why need to ask !?
