auto techniek (16th December, 2022)
i use xh keylessgo keys few times, all work ok
need to know too how to rightly use them and on what cars work ok and where cant be used
next time need to buy them from better and trustworthy dealer, where you get some support and help too
not from some f**ker who take money and after f*c* you with any help
more info in PM![]()
many thanks to friend kevfield
Willinickersen (4th January, 2023)
Hey guys and happy new year.
I have a problem with VVDI MB. It stopped working on CAN protocol. K-line cars work fine. I tested the cable and it's not faulty.
Has anyone come across with such problem? Clearly something in VVDI MB hardware...
server calculation and successful calculations became very slow
Hi.
Has anyone managed to renew keyless nec with rom59 or rom61?
I tried with several processors , each tamie the same rom 59 writes that's is not supported, rom 61 comes to 50% and gives an error.
I tried on adapter without soldering and on basic board too.
Same problem with ROM V61 today, after identify on both “NEC ZIF ADAPTER” and “SOLDERING NEC ADAPTER” the key can be identified with ROM V61.
But when pressing renew it goes to 50% and then it says: “Error: execute operation failed!”
In manual it says that it supports V61.
Has anyone lately tried to do a lost key on Mercedes W212, 2011 with the latest software? tried to do one yesterday via Ir or obd with no luck, looked on my files and saw i had done them before, with no problem, lucky for me the guy had a faulty Be key, which i managed to sort of repair, and got one shot to read the password.
Hello Mate,
I have key files calculation with my VVDI MB Tool.In fac having followed the procedure of the key calculation from the dump read with VVDI Prog from the EZS of a W164, i got the following message, (photo attached) and key files cant be calculated. Please share solution if you have ever experience this.
WBR,
Just ignor it, try again anther time, i had the same message on W212, i tried again after few minutes, all good, bug in the software, or server biusy.
ngakson2002 (26th March, 2023)
Have any of your colleagues had this problem with vvdi mb tool,and can i just change the battery or must an expert from xhorse
Many people already discussed this issue. Return to your seller or use search for the dangerous home solution.
Hi.
I need help, my mb bga vvdi tool was showing a low battery warning, now it won't SYNC.
What should I do to resume operation, to synchronize tool and software?
Thanks.
