Car fuel gauge is not working properly, I sometimes get 2 bubbles showing on a full tank of fuel, and it stays that way all day or longer, then goes to 3 or 4 bubbles, what gives here?
Anybody know this problem?
Dash ref. A454 54 32 11
Eprom 93C66
Eprom 93C66
Recalibrate fuel pump with empty fuel tank
TapaTalk for Windows phone.
Ok
Tomorrow try this.
Thanks.
Have seen this fault on three of the four smart forfour's i have repaired...re-solder both, problem solved
there are 2 resistors in parallel on the dash pcb... 32ohm surface mount. one of them has a dry joint.WP_20151206_001.jpg
byyoyo (8th June, 2023), evisdaci (14th August, 2019), panderetamix (6th April, 2016), plays (16th May, 2019), sagie (21st February, 2019)
If you are talking about those resistors labeled "331", they are 330 ohm, not 32. I couldn't find any 32ohm resistors in your picture.
Anyway, thanks for the tip, much appreciated.
Yep, you are correct, 330 ohm. With the dry joint the fuel gauge would randomly jump to 2 or 3 bars.
usualy you have to reset with das.
empty fuel tank and reset to zero dash bars with das
thanks a lot for the problem solved
