Hello , I'm here with a problem if there is someone who can help I thank.replaces the CIM module of a opel vectra c for a new coming of Opel, have the original pin in the car pass. I programmed with opelcom all configurations as was in the original program, the keys ok programmed., and ECU ligt tool on in dasboard , in the ECU error P1616 = CIM (steering column module)
environment identifier wrong immobilizer B-006 and P1614 = key transponder immobilizer wrong B-006, outhers modules in the left door and passenger door, bcm, etc .. is the same error.someone can help with any ideas or say that I am wrong.thank to do you best regards
in opcom error cim:OP-COM 100219a - PC based diagnostic tool
hkj
OP-COM - CAN Communication Window> 2007 (7)|Vectra-C / Signum|Body|CIM (Steering Column Module)
Read Info...
Identifier: 0x0015
VIN: W0L0ZCF3561069632
Part Number:13204146
Software version number: 12244872_
Hardware key number: EOL-TESTER
System description: DELPH0400
Alpha code:
Manufacturing date: 150120
Code Index and version: 008 02
Total number of fault codes: 6
B3924 - Wrong Environment Identifier Received BCM (Body Control Module)
(00) - Present
B3925 - Wrong Environment Identifier Received IPC (Instrument)
(00) - Present
B3926 - Wrong Environment Identifier Received DDM (Driver Door Module)
(00) - Present
B3927 - Wrong Environment Identifier Received PDM (Passenger Door Module)
(00) - Present
B3929 - Wrong Environment Identifier Received REC (Rear Electrical Centre)
(00) - Present
U2103 - No Communication with CAN-Bus (High Speed)
(00) - Not present
