ok i need some help here.. ive been reading and reading and ordering things but i am still stuck.
i have installed xp32bit on a seperate laptop, checked that all drivers are in ok.
i have the following tools:
normal odb2 reader
VAG+K+CAN cable
Kess V2 china clone
AD900 pro (maybe i could read the codes i need from ECU to make a proper key ?)
I have a Mazda Premacy 2001 with immo problems. I was given an ecu, ignition, immo box. but they are from a manually geared premacy and
mine is automatic. So i tried to just switch ecu, immo box and ignition and the car starts right away, but will not change gears as this is
ecu from a manual driven car. mine is called FP89 and the one i installed is called FP88
I cant even get kess to ID or Read or anything. i get the error: " error reading hw serial" (i think it was that) no matter what protocol i use
etc. (trying to read via obd2 connector which is 17pin on mazda so i have an adapter cable.
can anyone help me on skype/teamviewer ?
i have 2 sets of ecu,keys+ignition+immo box. the original ecu wont start car for more then 3-4 sec. the new one starts fine (alot of black smoke though) but will not change gears.
what is the easiest way to do this? use new immo and change/flash it if its compatible between fp88 and 89? or use original immo?
what would i need to to for the new ecu from the manual transmission car to work for automatic transmission ? as i have a key that works with the
car and no error codes, just wont drive/change gears
im having voltage and all sorts of problems.. so, if anyone is up for helping me a bit on teamviewer and/or skype,
here below are vin numbers and denso part numbers etc
VIN: JMZCP19P501135807
ecu = FP89 EGI 18 881B - 279700-0831
Siemens SID801 (i think?) 93c56 chip
AGAiT 33920-83e2 DENSO??
so someone pleeeease help me, this car will rust to death soon![]()
