Results 1 to 15 of 18
    Slem's Avatar
    Oct 2015
    Default All smart keys lost Toyota Prado 2015 - SOLVED -
    I would like to thank the DK forum and below DK members : Mr. Gwee, iamfooser, Siham and aketokediag to help me solving the problem. The solution came mainly from Mr Gwee .. I'm very thankful from him . Just to remember the case ..
    I have Toyota Prado 2015 with all smart key lost .. I made a new smart key in Tango by dump of smart box 93c86 but the security LED still flashing, Steering still locked and no engine start. Only the ignition is ON. I tried to add another new smart key via the scanner with no luck, Its give me the code DTC U0327 Software Incompatibility with Vehicle Security Control Module
    the car is new and every thing seems to be new.
    The attachments are the Smart box, Immo box and steering box files .. just write them and add smart key directly ..
    Slem
  2. The Following 37 Users Say Thank You to Slem For This Useful Post:
    abdomm (26th April, 2016), AndriyM6 (27th October, 2016), asmatullah (14th August, 2023), Brayn (7th November, 2015), CLK1201 (7th November, 2015), DavidGama (31st May, 2018), digikeys (8th November, 2015), DOUGLASDL (7th November, 2015), dyzio (7th November, 2015), dziongas (30th October, 2019), ecufix (24th August, 2023), Eyasu (14th June, 2021), fadhle (7th November, 2015), garagetech (9th March, 2016), geeroam (10th November, 2015), gobon1 (11th November, 2023), gokhanusta (7th November, 2015), hatimtai (7th November, 2015), ibratex (15th July, 2016), ilhafi (11th February, 2016), Jobeso66 (2nd December, 2018), just4upal (13th August, 2020), kamikazedr (15th March, 2016), kenrique10 (11th October, 2017), kronk92 (12th October, 2016), lion0304 (18th July, 2016), m-o-y (7th November, 2015), metercar (25th August, 2021), mvtamele (4th December, 2015), nguyenduccuong (11th August, 2018), pike (2nd December, 2015), quattro210 (27th October, 2016), saboorvayani (8th November, 2015), Sake (2nd September, 2021), smart2key (13th April, 2016), Wilber Pardo (16th February, 2016), Zohar (7th November, 2015)
  3. #2
    Oct 2015
    Moderator
    PremierD's Avatar
    Jun 2009
    Someone wants Jam on it now .... ...ffs read the post
    . "please check the attached reset dumps free for all DK members to be able to solve similar issues .. the attachments are the Smart box, Immo box and steering box files .. just write them and add smart key directly .. Thanks "Slem
  5. The Following 5 Users Say Thank You to PremierD For This Useful Post:
    DOUGLASDL (8th November, 2015), fadhle (7th November, 2015), Jobeso66 (2nd December, 2018), Johnner (7th November, 2015), super jumbe (2nd December, 2015)
  6. #4
    Mar 2011
    Thank you slem for your gift, i remember gifts from Master Gwee.
  7. The Following User Says Thank You to fadhle For This Useful Post:
  8. #5
    Jul 2015
    You are always welcome Slem, thanks for the useful post.
  9. The Following User Says Thank You to aketokediag For This Useful Post:
  10. #6
    Oct 2015
    gaborone botswana
    thank you salem am new to smart keys but what do you mean by adding the key directly
  11. The Following User Says Thank You to teeone For This Useful Post:
  12. #7
    Nov 2015
    felicitaci?n: Chuncky:
  13. #8
    Slem's Avatar
    Oct 2015
    Add key directly means .. after writing all the Bin files go to the car and connect the X100 key programmer or any devise can learn keys for toyota and with ign off just choose ADD KEY option and put the smart key near the coil its will beep twice means the successful programming . test the keys . Done
    Slem
  14. The Following 3 Users Say Thank You to Slem For This Useful Post:
    kamikazedr (15th March, 2016), kronk92 (12th October, 2016), teeone (9th March, 2016)
  15. #9
    Oct 2015
    gaborone botswana
    thnx slem appreciate
  16. #10
    May 2018
    South FL USA
    Default Files for Harrier (RX350)?
    Quote Originally Posted by Slem View Post
    Slem
    After replacing with (used) Certification ECU, we are also now getting U0327 Software Incompatibility With Vehicle Security
    Anyone know of this process would also work for a 2011 Lexus Rx350 aka Toyota Harrier?
  17. #11
    Aug 2018
    Yangon , Myanmar.
    Hi all dears,
    Today , I made key lost program with tango programmer for Lexus LS460 , 2007model . Smart control module is 89990-50010 and IC is 93C86 . I swap the bin file from that IC and made smart key with tango programmer. Tango gave reset file and back to IC . Tango generated smart key file to smart key via bin file of IC 93C86.
    When I use this smart key , dashboard light is ok , ignition is ok by touching smart key near start buttom . immo is ok . Doors locks are circle by smart remote buttom pressing. But not working smart system to start engine.
    As not working smart key , I programmed add new smart key . But not enable it . So I earsed keys with programmer . And I programed it again . In this time , even immo is not working except of ignition light ON. DTC is U0327
    I would like to want know how to solve this problem . Please anyone help me .
  18. #12
    Dec 2018
    Is there any DTC when immo working and start system was not working.
  19. #13
    Jan 2018
    it's really honorable of you
    ss
  20. #14
    May 2023
    Slem
    Plesse i can not find the Attachés files can you maybe mail them to me
  21. #15
    Jun 2019
    password please
