Please remove error 2513 - Inlet port shut off the engine so that disconect plug from Mercedes A-Class - ECU edc16c32 180cdi. The attached flash is off the DPF by ATR.
here it is removed 2513
I can disconnect the plug so that it was not safe mode?
mate I removed desired from you dtc
did not work. whether connected or disconnected continues to be the same mistake in 2513
Make: Mercedes
Model: 169.008 - A 200 CDI Sedan
Year:
VIN:
Test Time: 2015-11-07 20:26:33
Diagnostic path: System Selection > 169-A Class(Up to 11/2005) > Sedan > Diesel engine > Left-hand
steering > 169.008 - A 200 CDI Sedan > Control units > Drive > ECM - Engine Control Module(CDI)
Diagnostic Result
2513-1 Check component M55(Inlet port shutoff motor).Positioner
signals fault X.
for such car it need to disable M55 actuator also to disable dtc label from flash file !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
This will help anyone because I already have enough of that car.
Is not removed because you need to read this ecu on a bench.
And only with dtc off you can not have decision with your M55.
flash BDM. After disconnecting the plug is now error 2530-4 and shines a light on the board.
2513 dtc off
Blaze,please post that again in English
Thank you...
"Dtc 2530 off
regards"
haha
Problem solved. Do not just turn off only the errors DTC![]()
