Need pinout to power up UCH unit
I will connect dash to UCH and see if dash is working or for repair.
Even need how to connect OBD to UCH
ImageUploadedByTapatalk1447325470.531581.jpgImageUploadedByTapatalk1447325484.149480.jpg
Connector PP3 Pin 2 -> earth
Connector PP1 Pin 1 -> earth
Connector PP1 Pin 3 and 4 -> 12V
Connector PE2 Pin 8 -> CAN High connect to OBD Pin 6 and Pin 30 on dash
Connector PE2 Pin 18 -> CAN Low connect to OBD Pin 14 and Pin 29 on dash
Connector PE1 Pin 7 -> to start/stop switch (short to ground for short time to Light up dash)
Beetwen CAN lines connect 120 ohms resistor.
Mbi, BIG THX!!!!
mbi : do you perhaps know which pins are the one to change what is displayed on dashboard ... so UCH would send the message to dash... to show km, consumption,...
br
Steering column switches are connected to UCH but If I remember well it's not clearly indicated on wiring diagrams which pin is used for this function and what signal.
Currently I have CAN emulator to check dash, show km.
INFO Pour le connecteur UCH
Armenio Dias (10th June, 2017), capi (17th April, 2016), Col19 (28th February, 2025), Dr Alex (31st August, 2019), florin_leo (10th April, 2021), Jashmine1983 (25th October, 2017), kronk92 (27th December, 2023), martinracing (6th December, 2017), mbail (1st July, 2018), serviplus9 (8th May, 2020), wowa557 (19th December, 2021)
hi all, i connected all but not sucess. I want connect uch to obd to do diagnostic/programming and connect too a dash
so, is this pinout?
PP3 Pin2: GND
PP1 Pin1: GND
PP1 Pin3,4: +12V
PE2 Pin8: CAN-H to OBD Pin6 and Pin30 from dash
PE2 Pin18 CAN-L to OBD Pin14 and Pin29 from dash
PE1 Pin7: touch to ground to activate dash
And put 120ohm resistor between CAN lines
I connected by these pins
hrmotorsport (13th September, 2019), kronk92 (27th December, 2023)
Thanks sir, tomorrow i will check
Br
Enviado desde mi iPhone utilizando Tapatalk
i cant connect only with this pinout, is needed put dash? resistor? thanks
120 ом подключить? уч работать?
Sorry i dont understand. Finally i connected qith uch and dash using my pinout and put resistor between can h y l
Thanks a lot
Catalizator (14th September, 2019)
when connecting on a bench, you should always use a resistor. working blocks are not always taken from the landfill. therefore, you do not need to blame yourself for incorrect connection to the pins
hrmotorsport (14th September, 2019)
On reader:
PIN 1 empty
PIN 2 Light (Only requiered if you'll use it as bedside lamp)
PIN 3 + 12V
PIN 4 Data signal to UCH PE2 PIN 39
PIN 5 Ground
PIN 6 Synchro to UCH PE2 PIN 40
Tested working.
Greetings,
