We should get Nobel for this info![]()
need help
now my goal is to buy xp-005
who will help?
Dr Alex (10th April, 2020)
I understand your curiosity, but i did repair many electric locks without return and without test because the hardest is to open them without blow up of the small security locking pin. Once you test them, virgin is to do gain, without test this second time...
rafal (10th April, 2020)
Louislesinge (10th April, 2020)
It seemed to me that you knew a lot about the Renault...
Yes correct what you are saying,not necessary a test after virgin esl.
Many of my work is in the bench so I try to create this harness connections to simulate car,so with this process I can code new keys,code new esl etc etc and then ship the all kit to costumer fully working.
And yes I’m a bit curious how systems work,that’s the reason for create this connections.
Enviado do meu iPhone usando o Tapatalk
asto (11th May, 2021)
Ok,
I don't know how is the situation about Scénic- Mégane II/ Clio III in your country but here around me, there are so many cars going for scrapping that the price for the whole starting kits is going down and down (sometimes < 100€). People sell much better virgin parts than full kits.
Now I have one UPC here,let’s see where this is going to
asto (11th May, 2021), Louislesinge (11th April, 2020)
Hi, I read with great interest this topic.
My scenic 2007 do not start and show the famous "turn steering wheel + start" dashboard message. The steering is not locked and I cannot communicate with the CAN bus with my ELM327 ...
So I have put the UCH on the table to power it alone, and try to communicate (I want to read errors code).
By using my documentation, I did exactly what you described, except the PE1 pin7 shorted to ground to wake up the UCH, and the 120 ohms CAN resistor !
I have used connector PE2 pin 6 (CAN H) and pin 16 (CAN L) (they are shorted on the pcb with pin 8 and 18, so it is the same) to connect it to my odb ELM327 Pin 6 and 14.
I have also connected ground and +12v to the ELM327 obd plug pin 4,5 et 16.
When I ground PE1 Pin 7, a component is shortly "singing" on the board, I think it is a coil, and the current consumption briefly increases to 500mA.
... but damned, I cannot communicate anymore.
If you have an idea (except to hit him with a hammer) I would greatly appreciate it.
Here is the bord and "the singing coil":
Zoom on it:
Kojot71 (25th January, 2025)
