Results 1 to 3 of 3
    May 2011
    Ireland
    Default VW Caddy 1.9 sdi(BST engine code) wiring diagram ,ecu pinout need
    hi all,
    I have VW Caddy 2006 2.0 sdi (bst engine code) with no power problem.
    2 permanent fault in the ecu
    17564 Manofold pressure sensor (g71)- open short to ground p1156
    16497-Intake Air Temp sensor G42- signal high.
    I changed 2 sensor but still same problem and same faults. Look like there is a problem with wiring or ecu. I have to chcek it.
    I need wiring diagram or ecu pinout for this car.
    Let me know if you have.
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Map sensor no power supply...1wire gnd 1wire + 12 or 5 volt and 1 signal....when open bonnet seen wiring little left from batery
  3. The Following User Says Thank You to vasko For This Useful Post:
    czaderx (17th November, 2015)
    May 2011
    Ireland
    Wiring damaged beside battery. All good right now.
