Results 1 to 15 of 16
    Jan 2015
    MOROCCO
    Default opel insignia 2010 pin code
    hi i need opel insignia 2010 pin code from eprom 24c16 plz
    thks
    Bllinda's Avatar
    Baltic
    .... .... x30x
    Quote Originally Posted by issam2 View Post
    thks
    today
    A topic that interests me
    vlaki electric's Avatar
    Jan 2015
    serbia
    4306 is pin code
  4. The Following 2 Users Say Thank You to vlaki electric For This Useful Post:
    issam2 (19th November, 2015), zckariya70 (23rd November, 2015)
    Dec 2013
    TRY ..4306..
  6. The Following User Says Thank You to ABD ERRAHMANE For This Useful Post:
    Jan 2015
    MOROCCO
    will try and report thks
  8. #6
    Oct 2013
    Usa
    thks
    try these coed 4306
  9. The Following User Says Thank You to neimy For This Useful Post:
  10. #7
    UK East
    is this from the BCM?
    EDIT: scrub that, yes it is....
  11. #8
    Bllinda's Avatar
    Baltic
    .... yes ....
    Quote Originally Posted by plasma533 View Post
    today
  12. The Following User Says Thank You to Bllinda For This Useful Post:
    plasma533 (17th November, 2015)
  13. #9
    Jan 2015
    MOROCCO
    4306 the code is ok thanks every body
  14. #10
    levisdj's Avatar
    EcuLand
    To reprogram keys do you need pincode from BCM or from dash ? Or it's the same ???
  15. #11
    Zapp's Avatar
    Sep 2010
    Liverpool
    Quote Originally Posted by levisdj View Post
    If there from the same car, pin is the same
  16. The Following User Says Thank You to Zapp For This Useful Post:
    levisdj (24th October, 2017)
  17. #12
    levisdj's Avatar
    EcuLand
    it's from the same car, yes, not recognising keys after battery went flat, what could be wrong ?
  18. #13
    UK East
    wonder if BCM has forgotten the keys, was a common issue on the corsa d
  19. #14
    levisdj's Avatar
    EcuLand
    So what's the procedure ?
    Edit : I have B389A-00 Enviroment Identification stored in BCM, what could be the problem ?
  20. #15
    Bllinda's Avatar
    Baltic
    Dtc B389A-00 occurs after bcm change or unsuccessful programming ....
    today
  21. The Following User Says Thank You to Bllinda For This Useful Post:
    levisdj (25th October, 2017)
