Results 1 to 15 of 18
    Mar 2012
    Angry 08 Volvo XC70 CEM replacement
    Hey guys!
    I have a CEM to replace (with a used one) on a 2008 volvo XC70.
    Replacement module have same part number, but as per scrapyard, it comes from a 2010 V70.
    Part number: 7G9T-14C256-FA
    I opened the original module, separate both board because memory was in sandwich between both board and could not be reach otherwise, and I found a M32C Renesas processor with what seems to be a 25LC320 just beside.
    I have read/verify eeprom and Renesas with success, and I have transfer both dump in the new module. (didn't separate both board on the "new" one, as I find the pads in the back of the board to read and write both MCU and eeprom without disassembling the unit)
    problem is that I have installed the new unit in vehicle, and nothing power up... not even the headlamp when you turn them on.
    before I transfer the dump, my customer told me he installed the new unit and key was not catching in "ignition switch". it was pushed back.
    with the transfer done, now the key catches in ignition switch, but is unable to get out of it. stuck there.
    will not switch ignition on, nothing is working in the vehicle... seems to me like if the flash would have been corrupted????
    when I installed back the original unit, the key was able to get in and out of the ignition switch and vehicle still start. so at least my original module is still ok.
    both dump of both module read and verify ok, and after I wrote the new dumps, they verify ok.
    someone have already achieved to transfer memory in those type of CEM?
    anyone have any input on this one?
    many thanks for your help guys!
    vanos batam's Avatar
    Batam-Indonesia
    Attatc photo of the BCM..
    Maybe i have full dump.
    _______________ D3-oToprog _________________
    ig : vanos_batam
    Mar 2012
    Quote Originally Posted by vanos batam View Post
    here are a few pictures + the connexion in the back of the board + full dump of both module.
    as I understood, eeprom is encrypted and you cannot just swap eeprom memory. you also have to swap the matching flash dump. am I right to say that?
  4. The Following 9 Users Say Thank You to MV auto For This Useful Post:
    dikdom (4th August, 2016), Jobeso66 (11th November, 2018), kaponne (30th August, 2016), kitachu (20th November, 2015), line44 (29th July, 2024), marinov78 (1st July, 2024), mmm_pl (24th August, 2016), OalikO (5th December, 2017)
    Batam-Indonesia
    Quote Originally Posted by MV auto View Post
    iam sorry
    i dont have this
    you may ask ​lupu_sandu
    ig : vanos_batam
  6. The Following User Says Thank You to vanos batam For This Useful Post:
    MV auto (20th November, 2015)
    Aug 2015
    Hello Everyone,
    I'll continue this thread.
    Maybe anyone have experience with 6G9T-14C256-HF 30786819 AA. How to connect the pads in the back of the board to read 25LC320.
  8. #6
    GameTheoryOptimal's Avatar
    Jun 2016
    Canada
    look at post #3 buddy!
  9. #7
    Aug 2015
    Quote Originally Posted by GameTheoryOptimal View Post
    Thanks for fast reply. I saw it I tried it with 7G9T-14C256-FA. It works .
    But 6G9T-14C256-HF have otherness. See attached picture.
    P.s. pictures not mine.
  10. #8
    Jun 2016
    Canada
    than you'll probably have to do R&D on your own...
    or wait for someone who has done one of those.
  11. #9
    Aug 2012
    SWEDEN STOCKHOLM
    Hello my freind you only take eeprom out off the cem board and copy flash from the old original part to second used part and install original eeprom to new CEM unit and car start push thanks after starting car.
  12. The Following 2 Users Say Thank You to Dani1979 For This Useful Post:
    Jobeso66 (11th November, 2018), line44 (29th July, 2024)
  13. #10
    Aug 2015
    Quote Originally Posted by Dani1979 View Post
    Why do not help just copy FLASH and EEPROM?
  14. #11
    Aug 2012
    SWEDEN STOCKHOLM
    You must copy flash in this CEM CONTROL model the older model don't need flash memory but this model yes you must do it as I say because VIN number
    Sent from my SM-G900F using Tapatalk
  15. The Following User Says Thank You to Dani1979 For This Useful Post:
  16. #12
    Aug 2012
    SWEDEN STOCKHOLM
    And my friend you must take out the eeprom and do it outside or put the original eeprom on new part and car start
  17. #13
    Aug 2015
    Do you mean read EEPROM on board will be incorrect? Or it depends from EEPROM readers ?
  18. #14
    Aug 2012
    SWEDEN STOCKHOLM
    Yes if you read the eeprom dump you crash starting file and if you not copy original flash to next part you will have airbag problem deferental 4?4 problem radio problem and many ecu don't conect to CEM again
  19. The Following User Says Thank You to Dani1979 For This Useful Post:
  20. #15
    Aug 2015
    Can I eeprom out, make a copy and put copy to second unit?
