Results 1 to 7 of 7
    dave11674's Avatar
    Florida, UK
    Default 2010 Hyundai iX35 1.7 vcdi EGR problems
    hi guys ive got a 2010 ix35 in
    egr fault P0404 egr circuit malfunction
    i got a few of my mates to try their swiftec soloutions on it
    each ones files were different
    so tried all 3
    but the car wont rev over 3000rpm and its in limp mode
    if he starts the car and then goes into the ecu with snap on and reads codes....nothing. BUT if he does a clear codes of the ecu the car will then allow him to full revs !! until he turns it off and restarts then its back to 3000rpm
    has anyone had this before ?
    and if so did you fix it and how did you fix it
    any help here greatly appreciated
    orig ECD17C08 micro file inc
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    Andrei2015's Avatar
    Oct 2015
    Default egr off
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
  3. The Following User Says Thank You to Andrei2015 For This Useful Post:
    dave11674 (27th November, 2015)
    dave11674's Avatar
    Florida, UK
    thanks andrei
    but car still doing same
    im not sure the EGR is causing problem now
    may be something else causing limp mode ?
    thanks anyways
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    With what tool did you read this ecu??
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    I think they used KTAG and readed like a 1.6Crd, ecu should be propably that same. I don't have any other idea don;t see nowhere supporting for 1.7 :-)
    but that's impressive 1.7 with Bosch... and with edc17, almost like old 'good' mercedes
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    Quote Originally Posted by CustomCars View Post
    I found it transdata will cover this engine in ix35, its on the vechicle list from 2013 version.
    CustomCars can you please confirm it as my ktag doesnt co-operate with transdata.
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by cheester View Post
    So needed make them cooperate with it.
    TMV and should be done :-)
