Originally Posted by
flyins
answer to 1, yes car wont crank
2, check security wait time in BCM and if it says I.E. 40mins, leave ignition on until its 0, also if someone just swap 93c86 this may cause you issue.
3, and it all goes like this mate IPC,BCM,SDM (airbag module),and engine ecu, thats everything that allows car to start when immo out of sync.
so to resync car your gonna need your pin and this procedure
Reset IPC
Reset BCM then reprogram a key(yes reprogram key now)
Reset SDM
turn key off now and wait 30 secs
Now reprogram IPC
reprogram BCM and in the immo selection say BCM installed
reprogram SDM
turn key off for 30 secs
then start car and reprogram any other keys
You wont need or shouldnt need to reset engine ecu or even say bcm/ecu installed in the immo selection in BCM, unless someone been messing, so dont reset engine ecu unless you getting nowhere, but you can try the pin to make sure it accepts pin
(Do not reset ECM before or at the same time as BCM is reset, otherwise data about the vehicle's key COULD be lost which would require new key transponders)
OPCOM or VAUXCOM procedure dont matter if orig or not
read pin from SDM (airbag) and reset it with its own pin and not the one from new kit! You can get pin from clocks for the new kit byte swapped aswell so ie see it as 1564 but actual pin is 5146 if from clocks ok,
all the best anyway also theres loads of posts on this if cant find any just P.M. me
