Hello all,
is there any possibility to read/write flash on this ECU: ?
Opel Simtec 71
Any advice to some flash-tool is welcome. I found only Abrites, but there i'm not sure, if it can do this job (and abrites is prety expensive)
Hello all,
Opel Simtec 71
Carprog,smoke,opelscannerflasher
Galetto2 works 100% with this ecu.
@cristi_bv
are you sure that Galleto2 works? I have Galleto2 and there is no Simtec71. Only Simtec 71.1
@soxten
CarProg can read only eeprom. I need r/w flash .
yes,i have done a few.it read's/writes without problem.For what you need to flash ecu?
Pali33 (9th December, 2015)
Galleto2 read only maps (only 23kB).
I need read/write whole flash content.
Know anybody some tool, which can read/write whole flash content of Simtec71? (not only maps (23kB), as Galleto)
Try I/O Terminal tool.
I/O Terminal is the right tool for this if you want to read it
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
Pali33 (18th December, 2015)
thanks for tip,
can you (or somebody else) confirm, that I/O Terminal read full flash, not only 23kB ?
Cristi_bv... What do you mean by saying that you have flashed theese ecus with galletto? Need a boot mode to make a full (256kb) flash, not 24kb as galletto and mpps and abrites does...i've made a boot mode on the hybrid simtec 71, but it acts strange. Digferent than simtec 71.6. on 71.6 it does enter in boot mode, but in hybrid 71 or 71.5 it does nothing when you read it with gal... Practically, it enters in boot mode, but when you try to read c167 - boot mode, it does not recognize it...
I/O Terminal can do it
