Hello
Friends, I am studying for solution, restart unit Blue&Me Fiat AlfaRome Iveco Lancia , went to block !!
system similar to mobile phones, Samsung system programming JTAG.
take advice
Thank you
Hello
take advice
Thank you
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
Post photos please...
hello, there are three models of ECU. everyone ARM9 system, with Nand as memory.
This unit shuts down after disconnected battery !! body computer signal can not find !! kilometers and flash
this is Blue&Me Fiat 500....
on site http://www.blueandme.net/blueandme/index.aspx/
you will find there are files to update system ..
sorry but this is a solution to restore the unit ?
open this post again, look for news how to restart or reload sw,
I tried read JTag con J-link, but with little success ... 4 years have passed since this post !
Meat-Head (30th January, 2021)
have you try to make update via usb stick?
thank you friend for the advice.
But this is not the solution![]()
device, it goes to block, he is like off, in diagnosis he does not answer anymore, it is like if you erase memory or go to block.
To restart it surely you need to load "firmware" ...
so I think...
With what tool try to make a diagnosis?
I remember once in blue and me (grande punto 2008) autocom (Delphi 2016) reset and delete the language, and I reflash it by USB....
Remove nand BGA and progamming.
only socket is very expensive
ascotauto (18th August, 2022)
I think one of the few programmers that can read and write these flash memories would be the elnec beeprog2 but between programmer and socket adapter you'll spend over 1300 euros
friends ... do you have new information on how to awaken this control unit ?? just replacing the NAND BGA ?
adrianojeminaj9 (5th May, 2020)
Nq278 it is over the arm 9 with these we can look for the gate
Inviato dal mio iPhone utilizzando Tapatalk
someone can help me to find the original file dump of this nand?
adrianojeminaj9 (6th June, 2020)
