CARPROG collection all you need USB reset couter included
1.CARPROG UNLOCK FIRMWARE 4.74 WHIT J-LINK
2.Carprog update tokens by USB
3. All rework you need (included pictures) to make you device 100% work
-Softwares from 3.60 to 7.27
-Carprog Manuals for differents functions
-Counter Reset by USB for 4.01 version [Solution by MasterDiagPRO ]
-Lib Files for clone 4.01 and 4.74 version.
-Reprograming solution for Atmega, with manuals, with H-JTAG and J-LINK Segger.
-Solutions for fix Adapters Cables, and some schematic.
-Solutions for fix Pcb faults.
-Solution for Antena issue, Not read.
-Scheme for Hw test.
You can unbrick/unlock your locked CarProg Clone and reset counter via USB from now on! only 4.01 version
1. Download
2. Extract
3. Disable Internet connections (LAN, WiFi etc.)
4. Connect CarProg to your computer and run unlockOK.exe
5. Go to UPDATE -> INTERNET
6. WAIT
7. Done!
ok-opel vivaro 2009 autoliv unit crasch clear works fine eeprom 95160
ok- Opel CDR 500 read pin code/serial thru OBD connector OK. (Only need to bridge pin 3 and 7 on A1 adapter as K-line is on pin 3.)
ok - Ford ecosport airbag crash erase diag - work
ok - Old kangoo dash with 908
NOT - 2004 Vectra C EDC16.Vin and mileage was ok but pin code was wrong
ok - corolla 1999 93c66 immo key adaptation work perfect (TABLE)
ok - SAAB 93 2008 9s12 works well
ok - airbag opel corsa 24 439 954 doing all ok but in auto not clired
ok - Fiat Ducato 2009 by OBD+A1 - correction successful.
ok - audi dash repair to two cars audi a3 with blinking lights problem.......success
ok - fiat punto 03 odo adjustment by obd.....success
ok - opel ecu hybrid corsa bosch m1.5.5 pin code read and reset by obd on table.....success
ok - renault megane scenic old 1997 model key pin code read and write.....success
ok - Panda by OBD - ok
ok - A4 RB4 obd - ok
ok - Espace read pin by obd ok
ok - Astra H read pin ECU by obd - ok
ok - Clio airbag hc12d60 by obd - ok
NOT - Peugeot 307 BSI 2004 95160 not work
ok - Audi A4(05) rb8 read/write dash by obd OK
ok - China cable EWS BMW - fix db25 pin 10 and 11
ok - Renault Laguna MKII - resincyng car key after some i***t tried to add another key and adding a new key- OK via OBD
NOT - Carprog ( original ) can't read SAAB PSG-16. I need get another to car, how I can make synch with immo?
ok - mercedes vito 2002, magneti mareli cluster via dash connectors, thro dashboard section, read OK, write OK. sw 4.86
NOT - dashboard ford focus 2008 not working , not read with carprog clone, A1+FORD+ 12V EXTERNAL CAN, NOT WORKING
ok - Ford Focus year 2006 low line dash worked alright, with only A1 adapter and no external power.
NOT - read km focus 2008 and does not work, has MC9S12XHZ512VAL
ok - i done ford fusion 2008 whit external power a1 cable no problem whitout power no work
OK - Skoda Fabia VW5 airbag with HC08 - diag is a NO GO, but still, I managed to clear it on the bench.
ok - vw polo 96c86 by v4.86 and reads fine
NOT - Tested A3 2005 for fun today, km read ok, write nothing....
ok - Ford S-Max, dashboard - Lo, 2008 year, Read-write as Galaxy
ok - Tested on Fiat Stilo 2003 (after backup eeprom with upa) - read/write OK.
ok - Tested on Focus 2005 (after backup with Smok Ford) - read/write ok
ok - 2007 Passat and octavia dash ok. ReadEEP/writeEEP/KM/decryptEEP all ok.
ok - Laguna 2004 threw dash connector - ok (im not sure, prapobly hc08 dash)
ok - Focus 2004 OBD - game over - had to reconnect battery/dash to reset cpu.
ok - Citroen Berlingo HC08, read and write OK.
ok - Fiat Punto by OBD2, read and write OK.
NOT - Fiat Stilo diesel 2005 dash ,read by OBD, km real, after write got ------ and Dash Error. Mcu 0L26M inside, 912D60 ver2 by NYO - Easy cured with Xprog and NYO4
NOT - Golf 5 Visteon with 95160 or 95320 NOT CAN, DO NOT TRY, KILL THE DASH !
ok - Z14XE work ok
ok - VITO 1999y Airback reset ok
ok - Audi A6 from 2005 to 2006 dash km change ok
ok - Opel Z14XEP(BOSCH 6.2.2) dont work
ok - 1.7 DELCO WORK ok
OK - mercedes vito 2001 motorola inside pin conetion working good carprog clone
ok - try carprog clone on ford fusion 08 plate by obd cable and plus ford cable NEED +12
ok - passat 2007 tdi with c.p,change km ok,read eeprom ok,the edc make wth other tool becouse in c.p 4,85 its n.a
ok - Astra-H 1.4l - ECU - Z14XEP (ME7.6.2) CAN, hibrid, PIN , mil , VIN - R/W OK, Reset ECU - OK
NOT - Passat 2007 with micronas 3297 24c32 V15.01,EEPROM read write not work ,KM change work not ,connected OK. IMMO only FF
NOT - Touran 2007 with micronas 3297 24c32 EEprom read write not work ,KM change work not ,connected Ok.IMMO no read.
NOT - Ford focus 2008 km change diag not work .
ok - Skoda Octavia 2007 OBD > OK
ok - Audi A4 RB4 2003 OBD > OK
ok - SRS VW 6Q0 909 605 C + CP + A15-adapter + external 12V to CP.
NOT - tested on ASTRA H ecu DELPHI MT35E . read km , vin and pincode.
ok - Audi A4 2005 Dash BOSCH RB8 change KM via OBD - Adapter A1 Working 100% Read EEPROM - Woring 100%
ok - Clear Crash Airbag Ford Mondeo 2006 via OBD - OK!
ok - Add Chip-Card Renault Laguna II 2002 - OK!
NOT - BMW Key maker - BAD!
NOT - MB Key maker - BAD!
ok - Read/write MCU HC12 - OK!
ok - Opel Delco 1.7L read via OBD - OK!
ok - grand punto 2008 with carprog via obd
ok - Audi A4 2004 RB4 CRYPTO dash
ok - seat ibiza airbag unit 6q0909605s worked ok
ok - peugeot 307 airbag unit 5wk42908 worked ok
ok - jetta 2007 and 2008 micronas obd2 success
Please THX and rep if im help
